Question about CorelDRAW® Graphics Suite X3 Upgrade Version for PC
Corel 14 problem
The application you are using has become unstable .The wizerd will guid you through a seris of steps to help resolv this problem you. will be given the option to save your docoments & close the application as well you can send a report to corel doucomenting this problem in order that we may better serve you .TO COTINUE CLICK NEXT
This could be due to a problem with your graphics card. Check that your graphics card drivers are up to date and that they are capable of supporting corel.
Try opening a new file and working using wireframe you might find that this error doesn't happen, if so then it definately a graphics card problem.
nat.x
Posted on May 23, 2009
Quick words on word perfect go away
Go to the "WP13US.WPT" file according to the Operating system you have:
Windows 98 or Windows ME
C:\Windows\Application Data\Corel\PerfectExpert\13\EN\Custom WP Templates\WP13US.WPT
Windows NT 4
C:\WinNT\Profiles\"username"\Application Data\Corel\PerfectExpert\13\EN\Custom WP Templates\WP13US.WPT
Windows 2000 or Windows XP
NOTE: In Windows 2000 and Windows XP, the Application Data folder is a hidden folder. See instructions below to enable Windows to view hidden folders or to navigate directly to this folder.
C:\Documents and Settings\"username"\Application Data\Corel\PerfectExpert\13\EN\Custom WP Templates\WP13US.WPT
Windows Vista
C:\Users\"username"\AppData\Roaming\Corel\PerfectExpert\13\EN\Custom WP Templates\WP13US.WPT
Than follow these steps:
1. Rightclick on the template
2. Choose Properties
3. Untick the "Read Only" box
4. Click "Apply" than OK
Sep 20, 2012 | Corel WordPerfect Office X5 Standard...
Tip
Excellent guide. This guide indicated my fault could well lie on the T-con...
This is the basic guide that can be applied to most LCD flat panel TV.
By Bud Martin
First, try unplugging it from the outlet for about an hour to see if the TV will reset itself since the minute the TV is plugged into the wall, the power supply and processor will be running 24/7 and the EPROM can get corrupted by spikes and surges. Try using good quality surge suppressor to see if it will help if it happen often.
Look for burnt brown hot spots on the circuit boards, capacitors with leaking/bulging top or seals. Loose wires and connectors. Blown fuses.
Notes: We are dealing with high voltage that can kill you! so if you are not sure what you are doing, please have it fixed by the pro that has proper tools and safety equipment. Try to use GFI outlet and isolation transformer when work around the TV set and DO NOT DEFEAT THE GROUND PIN OF THE OUTLET/POWER CORD.
1) The power supply module (There are 4 regulated output voltages:- Standby 5vdc, switched 5vdc, 12~16vdc, and 24vdc).
The power supply converts the 120/230vac 50/60Hz into DC, then the high frequency (50~100kHz) switching circuits convert it back to AC but at high frequency which allows the power supply to use smaller and much lighter weight transformers (Ferrite core instead of heavy iron core), then this high frequency AC voltage is fed to the rectifier Diodes to get the DC output and filtered by DC filter capacitors that must have low ESR (Equivalent Series Resistance), if general purpose electrolytic caps are use, they will fail within a year or less due to high ESR.
The power supply has Standby 5vdc (5VSB, this is a MUST have before anything else will work, when this voltage is not present, there will be no any indicator light on the front panel) which is always on the minute the TV is plugged into the AC outlet, so it is on 24/7 and that is why the power supply will fail even though you may use the a TV not very often. It will see all the voltage spikes and surges 24/7.
This 5vdc is used to power the Processor and the Infrared remote receiver module which will be waiting for the command from the remote control or from the power switch, when the Power on command is received, the Processor will send the turn on signal (3.3~5vdc) to the power supply module (PSON pin) to the switch on the main 5vdc for the rest of the logic and Tuner circuits, 12~16vdc for the sound amplifiers (mostly Class D amplifier for efficiency and small size) and for the T-CON board (interface board between the LCD panel, some T-CON uses 5vdc, and the Logic board), and 24vdc for the Back lights inverter board (if there is no 24vdc then no back light).
Common failures:
Blown main AC fuse due to shorted out Diodes, transistors.
Bad capacitors leaking or bulging tops:
Shorted Diodes, transistors in the DC output side.
Testing the power supply output with dummy load:
24vdc testing: Disconnect the wires that go to the inverter board first. You can use two #1157 (using both Lo & Hi filaments by paralleling them at the base) car light bulbs connected in series so they can handle the 24vdc, this will put light load (about 70w) on the 24vdc output, the voltage out should be steady at 24vdc (+/-2v), if not, the power supply has regulation problem.
12vdc testing: disconnect the 12vdc TV load from the power supply board and attach one #1157 (using just the Hi filament), the 12vdc output should stay at 12v (+/-1v), if not, the power supply has regulation problem.
You should see the lamps go on when the TV power switch is ON and go OFF when the TV is powered OFF.
2) Main Logic board (It has Processor, Tuner, Sound Processor, Sources selector, Power amplifiers for speakers, interface port to the T-CON board for pictures).
This logic board sends out the turn on signals (3.3~5vdc) to turn on the rest of the Power supply module (Switched main 5vdc, 12~16vdc, and 24vdc), Inverter backlight ON (if no back light on command then there is no back lights),
Logic board supplies 5 or 12vdc to T-CON board B+ pin through switched transistor if T-CON board does not get the voltage from the logic board, you will get white/gray glowing screen without pictures.
Back lights Dimming (PWM) control signal.
3) Back lights Inverter board. Its job is to provide the drive voltage for the CCFL (Cold Cathode Fluorescent Lamp) to give white light for the screen.
This board is fed by the switched 24vdc (VBL) from the power supply module, it also get the Back lights on (BL on) control signal and the Dimming (Dim/PWM/) signal from the logic board. So for it to work, it needs 24vdc and the BL_ON signal.
Common failures:
Blown surface mounted fuses due to shorted transistors/ICs, Transformers.
Bad capacitors.
4) The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
5) LCD panel assembly to display pictures. The LCD pixels will block or unblock the back lights from the back of the panel to the front of the panel. This is the most expensive part of the TV, it will be more than the TV is worth.
As you can see, you must have all the above Voltages and signals for the TV to work properly. This may help you narrowing down the bad modules instead of buying the wrong module just to find out later that it did not solve the problem. Hope this will help you out.
Sound problem:
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
Inverter board connector: you can also see the Fuse 4A/160V
http://i.fixya.nethttp://i.fixya.net13ca788.jpg
Power supply connector:
http://i.fixya.nethttp://i.fixya.net78e0d9a.jpg
http://i.fixya.nethttp://i.fixya.net2fc510f.jpg
T-CON board: (metal cover shielding is removed to show the bd.)
http://i.fixya.nethttp://i.fixya.net0b5367e.jpg
Inverter board:
http://i.fixya.nethttp://i.fixya.netaf0a695.jpg
Logic board:
http://i.fixya.nethttp://i.fixya.net4bd108e.jpg
T-CON board is dead, no power or blown fuse on the board, screen turns WHITE, must see it in darkened room, otherwise you may mistaken it for failed backlight.
http://i.fixya.nethttp://i.fixya.net3a91b68.jpg
Bad T-CON board after warm up, you get lines, multiple pictures, strange colors blotches, etc.
http://i.fixya.nethttp://i.fixya.netd3cf194.jpg
Bad caps (leaking/bulging tops). Make sure to replace bad cap with good cap such as PANASONIC FM or FC series , they are Low ESR (Equivalent Series Resistance) which is a must for switch mode power supply, and 105c rating. Do not use generic electrolytic caps.
http://en.wikipedia.org/wiki/Capacitor_plague
http://i.fixya.nethttp://i.fixya.netbe827ec.jpg
Bad T-CON board or power supply problem
http://i.fixya.nethttp://i.fixya.net034e1db.jpg
24vdc power supply output testing using two 12vdc car lamps in series.
http://i.fixya.nethttp://i.fixya.net4f2929c.jpg
Bad LCD panel, vertical 1~2 pixel wide lines
http://i.fixya.nethttp://i.fixya.net28e50c1.jpg
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Free service manuals: www.elektrotanya.com
on Dec 21, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How can i use my vuilt camera in my laptop ?? or how can i stall it?
Hi.
You may download the VAIO Camera Utility from the below link:
http://s02.download.sony.com/US/pc/ARACCU-00225713-0042.EXE
Download and install the Application from the above link.
Once you have installed the Application, you may use the Camera through this Application.
If you require the detailed steps to use the Application, please refer to the User Guide mentioned below.
http://www.docs.sony.com/release/VPCEA3_series.pdf
Please open the above link and refer to page # 43 to view the detailed steps to use the Camera.
Hope this helps.
Please feel free to contact for further assistance.
Thank you.
Suresh
Aug 09, 2011 | Sony VAIO EA Series Notebook Computer
I've been using paint shop pro photo x 2 for a year and i can no longer open it
from the start tab goto control pannel , select add or remove programs. under paintshop option , select change. after that select application repair. thats it. if this doesn't help some of it's files have become corrupt and you had to reinstall this application from your cd.
Feb 07, 2010 | Corel Paint Shop Pro Photo X2 Full Version...
Hi, I'm running Corel X4 on windows7 and the combine function has become unstable, sometimes working, sometimes not? Can you help?
Corel Draw (all versions) has had problems in the past with one or more of the program's features becoming unstable or not working. Even doing an uninstall and reinstalling the program won't correct the problem.
Corel suggests to open (create) another user account and to use that account with Corel Draw. This usually works.
Jan 20, 2010 | Corel Draw X4 Graphics Suite
Yahoo App crash
it may actually be caused by a trojan virus.The name of this nasty tv is called TrojenFake.Alert. Download the latest version of Trojan Remover 6.6.1 asap This Virus will continue to cause damage to your system until it becomes unstable
http://www.freedownloadsplace.com/Products/5740/Trojan-Remover-6.6.1
Dec 21, 2009 | Microsoft Windows Vista Ultimate Edition
I need to open a coreldraw 14 document for editing using coreldraw 12.
save your file in corel 12 format using corel 14 then open it on corel 12
Aug 31, 2009 | CorelDRAW Graphics Suite 12...
Corel draw is not open plz help me
coreldraw x5 (Portable Vertion) not opend.
Error :
The application was unable to load a required component :
CrlUtl.dll. Please contact the publisher of this application for more information.
Jun 13, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Turn off automatically
its in the "performance information and tools" file in the control panel. when i click "rate this computer" link, my laptop will turn off automatically. after that, when i turn it on again, it seem like my laptop becoming unstable. it will turn off anytime it want.
Oct 21, 2008 | Acer Aspire 5500 5570-2609 Laptop
CorelDRAW® Graphics Suite X3 Upgrade Version for PC Logo
368 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
