The system runs but both the high and low so pressure erratically go up and down. the low side does not go under 600kpa, the high side between 1500 and 2000kpa. the system is an lg ducted on R22 refrigerant
  • 400 Answers
This can be caused by moisture in the system and when the moisture freezes on the capilliary tube you get a fluctuation, it the defrosts and passes through and again causes an up and down. Same would apply for excessive air in the system. You would have to do a long vacuum and possibly instal an inline filter drier.
Posted on Mar 10, 2009
What is the low side pressure for the ac at 100* for a 2001 5.3 silverado 1500 ext cab
as the temp rises so do the pressures high side and low side, at 100 degress outside low side pressure should in the area of 41 to 57 psi depending on hunidity.
Jul 01, 2012 | 2001 Chevrolet Silverado 1500
Temp off air coming out of register 74 degrees suction line temp is 42 degrees but high side line isnt warm dont look like it is wanting to take freon either compressor is running new system low side is...
Hello, what is your high side pressure? A bad compressor will show abnormally high low side pressure with abnormally low high side pressure. That 45 low side pressure is low And superheat high. If you high side pressure is normal toma little above normal but the low side remains low you have a restriction in the system, that might be why it's not taking in tne freon. Let me know you high side pressure
May 11, 2011 | Goodman Heating & Cooling
Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Dec 31, 2009 | Vintage Keeper Koolspace Wine Cellar
AC not cooling for 97 Passat TDI
A/c should be charged on the low side while engine is running. Make sure high side valve is turned off. Low side reading should be around 32-35 psi at idle high side should not go above 250. I hope this helps,good luck
Aug 01, 2009 | 1999 Volkswagen Passat
A/c for honda 2000 blows cold but has erratic high pressure readings very high and very low readings on low side
evacuate system and refill to proper spec for r13a refridgent may not have proper levels. check cooling fan opperation with engine running cooling fan should be opperating while a/c compressor is engaged. if all theese check out good has blockage in system
Jul 31, 2009 | 2000 Honda Civic
2004 Dodge Ram 1500 QC 4x4
28 TO 30 PSI ON LOW SIDE. HIGH SIDE PRESSURE 190 TO 200 PSI.
Jul 26, 2009 | 2004 Dodge Ram 1500
What are the charging pressures for the AC?
they very cause of hmidity and heat ,,,but ,,,about 40-45 on low side,,, and 200- 250 on a hot day for high side
Jun 28, 2009 | 1995 Chevrolet C1500
I cannot differentiate between the low pressure and high pressure
This is a little A/C 101. Follow the A/C lines. All A/C systems have a high pressure side and a low pressure side. The high pressure side is from the compressor to the condenser coil on the front of the vehicle to the evaporator coil in the dash. At the expansion valve in the evaporator the pressure drops. At the expansion valve the refrigerant changes from a liquid to a gas. This provides the cooling. The low pressure side is from the evaporator back to the compressor. Usually the high pressure lines are smaller than the low pressure (suction) lines.
Jun 13, 2009 | 2003 Chevrolet Silverado 1500
1993 buick century
Heater Control Module
May 31, 2009 | 1993 Buick Century
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
