My picture starts off great when first turned on and it's cold. Five seconds or so later the picture is angled to the screen so it is against the left side but tapers to the right and finishes short of the screen. The perspective is wrong. It is as though you are standing to the side of the TV to see the picture correctly, of course you can't. Also the picture is cut off on the left and the bit that is cut off is on the right side.
  • janellecooks Mar 16, 2009
    thanks
    But theres no power at all know
  • 59 Answers
Sounds to me that the bulb needs changeing pop into your local tv shop and they should be able to get a bulb for you.
Posted on Mar 10, 2009
While using my dewalt 7amp small angle grinder (using it on and off about an hour grinding hard walnut wood) I heard a pop inside the unit so I turned it off, then a few seconds later turned it on again it...
burnt out the motor
the fix is a new unit
when grinding or sanding you use light pressure and let the disc do the work
change or unclog the pad or disc on a regular basis
for fast rip down use very course then finish with a fine pad
Jul 31, 2017 | Dewalt 65091601 Brush Set D28110 D28112...
Monitor goes blank after 5 seconds, what do i need to do?
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 18, 2010 | Samsung T220HD LCD Monitor
From a cold start,power on,screen is all blue with "no signal" in the upper right corner. while still in blue screen mode approx 2 minutes after start a squealing sound starts. about 1 minute later the...
Sounds like a power supply fault due to leaky capacitors(electrolitics).
From cold take the back off and run a hair dryer over the power supply for a few minutes then switch on,if it comes up fully working then you have to isolate the faulty part/parts and replace.
Oct 01, 2009 | Polaroid FLM-3732 Television
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sometimes car won't start
It sounds like your mechanic is right, to me it sounds like its just a dirty old starter having trouble making contact and turning... thats all. Once you replace it with a new starter that has a clean armature and new solenoid, it should start like clockwork!
Jan 21, 2009 | 1990 Volvo 240
Five second delay with pump
check the intake of the pump. It may be clogged with sludge or debris.
Oct 02, 2008 | Little Giant 10 Cia, 1/2 Hp, 83 Gpm...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Mitsubishi WT-46807 46 in picture bends and the blue red and white all seperates
intermittent convergence fail. suggest re-soldering the 2 convergence output ICs on the middle power board. they are the 2 large devices located on the largest heat-sink on the middle board(looking at from back) once you re-solder them as long as the aren't faulty internally you should be all set.
Mar 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
TV image goes black, red light keeps flashing - hitting sometimes helps recover
you most have a cold solder but wachtout dont foolaround with tv sets they are very dangerous to a person that have no experiences with it and you could produce a larger damage..good luck...
Jul 24, 2006 | Toshiba 32A60 32" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
