Question about Apple iBook G4 (Z0AZW13397068) PC Notebook
CD drive + Flash drive not detected
I have just bought my iBpook G4 From a Friend and when CD/DVD Inserted it gets automatically ejected after few seconds & when Flash disk inserted it doesn't get detected
    Problem Solver:
  • 19 Answers
Some of the iBook G4 optical drives are very sensitive. The best way to test if it is still working is to use the System Disks that comes with every Mac.
Regarding the Flash disk, it may be that your iBook is using USB 1.1 protocol, while your Flash is using USB 2.0. You can check what type of USB your iBook has in the System Profiler. If it is 1.1, then you are out of luck. If its USB 2.0, then you have a faulty logic board.
Either way, not good news for you. Sorry.
Posted on Apr 28, 2009
Hey, i have which was working properly till yesterday. today whichi used and try to safely remove storage device windows showed me a message its cannot be stopped now or something.... so i manually removed. but it won;t detect now..what should i do?
Posted on Jul 08, 2009
4 Suggested Answers
seaniepie
  • 250 Answers
SOURCE: Disc drive ejects blank discs...plays dvds
Hi Again,
Sorry I didn't get back to you sooner. Work!
You need to let me know what type of PowerBook G4 it is as the instructions for each are different. However, what I will do is give you the links to the appropriate sites and some instructions for them:
  1. First you need to reset the Power Management Unit (PMU). To do this refer to THIS page. A little way down is a heading 'PowerBook and iBook models covered in this document'. Select the model listed in blue below this which will take you lower down the page to the instructions for your model.
  2. After restarting try your drive again. If it doesn't work, try a dvd drive cleaning disc.
  3. If it still doesn't work your drive is Kaput! If you're near Kent in the UK then I can help you out. If not find a local Apple Specialist who can replace the drive for you.
All the best
Sean
Posted on Dec 24, 2008
landsend
  • 1066 Answers
SOURCE: dvd will not eject from my iBook G4
Hold down the Apple and the E when you restart your computer.
Posted on Mar 13, 2009
thehumble1
  • 137 Answers
SOURCE: PowerBook G4 won't eject cd by any means found on apple support
If you can hear that it's trying, it might be getting pinched while trying to eject, especially if something pressed down on the case at that spot. Try gently widening the opening with a flat head screwdriver while you are ejecting the CD. just put the driver in and twist a bit to widen the slot. Also, check to make sure that the fuzzy stuff that brushes off the disk when you insert it - and keeps out dust - hasn't been damaged. If it is partially missing, the missing part may be inside, keeping the CD from ejecting.
Posted on Apr 17, 2009
CD/DVD RIVE NOT WORKING
This is a problem with several answers, however; for the most part, consider the Media that is inserted into the drive. If it is a COPY for example, the copy made on another computer may not line up correctly. The CD/DVD has magnetic lines that are true, very much like a phonograph record. If they do not line up correctly, they will not Read or Write. The other problem can be the Laser Head. If the reading head is misaligned, it too will have a problem reading data. The best way to get around the problem is to transfer the data from the CD/DVD media to a USB Flash drive, and go that route, or get an external USB CD/DVD for about 30 bucks at Wal Mart.
Feb 20, 2014 | Toshiba Style Bay DVD-RAM Drive Kit...
Mini cd wont load in dvd drive
try cleaning the lens with a q-tip and alcohol
Apr 22, 2012 | Toshiba Computers & Internet
The laptop burned a disc, then ejected as usual. Another disc was place in the tray, inserted as normal but this time a cd was unable to be burned because the laptop did not recognize the disc or any other...
The automatic ejection takes place when the burn process has completed successfully. Have your tried another writable CD or DVD? If your laptop is not recognizing any more writable CDs/DVDs, then the problem might be a failed CD/DVD drive. Otherwise, it is probably a bad CD or DVD.
Hope this helps.
May 26, 2011 | Computers & Internet
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Dvd stuck in ibook g4 disc drive
Here's possibility 1: from the apple forums" We had a repair come in at work with excactly the same issue, I managed to correct the issue by correcting the CD-Drive connection to the logic board, the customer had a very VERY big smile on his face once I had fixed. I felt so happy after this repair, unfortunatly, it earned our AASP no money tho. But it made me happy to see a smile I caused.
Possibility 2: firmware command:To eject a disc with Open Firmware commands, follow these steps:
1. Restart the computer .
2. Immediately after the startup sound, press and hold the key
combination Command-Option-O-F.
Note: The Command key has the Apple icon on it.
3. Release the keys when you see a white screen that says "Welcome to
Open Firmware."
4. At the prompt, type: eject cd
5. Press Return, then wait a few seconds. The disc drive should eject
any disc that is present, and "ok" appears behind your command when the
action is complete.
6. Type: mac-boot
7. Press Return.
Possiblity 3
If you can't get the CD to eject normally, reboot and hold the Option key. You'll see a startup drive select window. When the cursor changes to an arrow, (be patient, it may take a minute or two) then press your eject key, the CD will eject. You can also try holding the mouse/trackpad button down during a restart.
Jun 04, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
CD problem
there must be a hole near to eject button..insert pin into it and it wl eject automatically...
Feb 01, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
CD> player will not work
i have a ibook g4 it boots up but no oprating system comes up i have no cd player so how can i reload the os x and how do i enter the cmos to change the boot settings
Oct 20, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
MY DVD DRIVE DOES NOT DETECT DVD
Time to replace the drive.
A good source is newegg.com
Sep 01, 2008 | LG GSA-H42N 18xDVD+-R, 12xDVD-RAM,...
IMac with DVD issue
have you tried a cleaning disc? the buildup of gak on the lense could have become too bad to read, or the drive is toast.
Aug 01, 2008 | FastMac (APP-5691) for iBook G4 & iMac G5...
Repair dvd player dual audio
DVD / CD plastic housing breaks wear spring holds metal top pad to align CD /DVD on drive engine pad, most common problem.
May 15, 2008 | Jensen VM9510 Car DVD Player
Computers & Internet Logo
188 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
