Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
I want to splice a ps2 contoller with an xbox plug, so i can play my xbox with the comfort of my ps2 controller. but my ps2 controller has 8 wires and xbox only has 5 wires, so i need to get a wiring diagram so i can properly integrate the two.
Theyultmately do the same thing in the end why can't you combine ps2 wires and splice to xbox wires (although less wires) with the same properties? I'd find out which wire dies what and connect them according to properties. Don't forget to use the correct
Posted on Apr 18, 2011
  • 64 Answers
As far i know, that is not possible to splice a PS2 controller with an XBOX. As you said they have different wiring sets, so I highly doubt it will work.
Posted on Apr 16, 2009
I played my xbox for an hour or two last night.... i shut it off and unplugged it and my gf played ps2 for about an hour... then we went to sleep well today when i plugged it in nd tried to turn it back on...
You have have not mentioned what is not working the Xbox or the Ps2. Any way if the amber light does not turn on when you plug the Xbox into the wall socket you have lost the power adapter and do not attempt to repair it yourself . It is available on the net for 20$. In case of the Ps2 also its the same story. Replace the adapter.
Mar 07, 2011 | Video Game Consoles & Games
Tip
Xbox Controller to USB Conversion
Did you know the Xbox controller has a USB interface built-in? How would you feel about playing your favorite PC games, with an Xbox controller?
Here is what you will need to get the job done:
  • Xbox Game Controller
  • Male USB Connector
  • Wire Strippers
  • Electrical Tape
1. Using a Male-Female USB extension cable, cut off the male USB adapter, along with a foot or more of cable.
2. You will need to cut off the connector on the Xbox cable, too.
3. Cut the Xbox connector off right at the base, leaving you some room to splice on the USB Male connector.
4. Now strip off about an inch of casing from the end of each exposed cable that we’ll be connecting. There will be a lot of thin silver wires and foil wrapped around a few smaller, colored wires. The silver casing is the shielding, just trim it back enough to expose the colored wires.
5. Using your wire strippers, pull away the casing on each of the colored wires to expose the bare wire.
6. Splice together each wire of the USB adapter to its matching colored wire on the Xbox controller. The Xbox controller has an additional yellow wire, which you can ignore. Use electrical tape to cover up the bare leads, or heat shrink tubing.
7. You should now be able to set up the device and start using it. The first thing to do is to download the XBCD drivers (download here), and run the installer file.
8. Once the drivers are installed, plug in the controller and it should detect and install the drivers for “XBCD XBox Gamepad”. Now go to Programs -> XBCD -> Setup Utility and set up your new gamepad!
on Jul 12, 2010 | Video Game Consoles & Games
When i plug my controler in to port one it says please plug contoler in to port one
Early versions of the PS2 could be networked via an iLink port, though this had little game support and was dropped.
Oct 04, 2010 | Sony PlayStation 2 (PS2) Console
I am trying to connect an xbox 360 wireless contoller to my pc. I have followed the directions to download new software for Windos 7 64 bit but the contoller connects but does not do anything.
if your trying to use the controller to play games on your pc you cant unless u buy the microsoft adapter wireless gaming adapter for your computer, if your trying to just charge it, you just connect the charge cable to your usb drive and windows will automaticly find the drivers.
Apr 13, 2010 | Microsoft Xbox 360 Wireless Controller
Neither of my xBox 360 wireless controllers will sync with my 360 console. I have tried both contollers with a variaty of battery packs and they still wont sync but i have no problem with my wired...
Remove the batteries from both controllers, and unplug the Xbox for a minute. Now turn the Xbox on by the power button on the console, Install the batteries in your controllers, and hit the Console sync button first, then hit the little sync button on top of the controller.
If this does not work, you can purchase the wired charge pack that you must plug in to the USB port of the console to charge, and this will sync as your wired controller does. When it is synced unplug the wire from the controller and voila. Remember, the charger pack will look like this.
http://www.techsick.com/shop/images/P/xb360-controller-charger-36.jpg
Good luck and be patient.
Dec 19, 2009 | Microsoft Xbox 360 Controller
Can i play xbox game on ps2
No, and No. You will NEVER see a PS3 emulator for PS2 that would be impossible. Someday you may(very very very highly debatable) see an xbox emulator for PS2 but that is also highly unlikely. Nothing for either exists on the internet as an emulator for PS2.
Nov 23, 2008 | Sony PlayStation 2 (PS2) Console
PS2 OR PS2 SLIM
ps2 can play dvds but xbox needs a store bought xbox dvd remote to play dvds
the ps2 slim and the ps2 normal have a lot in common so thwere is not much difference, but the slim has a fliptop lid and the fat ps2 has a open and shut slide drive.If I were you I would get the slim because it is the only one you can get brand new nowadays. The xbox may have halo 1 and 2 but sometimes there are freezes on certain xboxes.
Jun 28, 2008 | Sony PlayStation 2 (PS2) Console
Logitech chillstream doesn't work for fifa08
The game your contoller won't work on is set for PS2 you could get a adapter for PS2 to PC if you own 1. The controller you got is set for XBOX confiq but works well on "games for windows games", Hope this helps!
Jun 27, 2008 | Logitech ChillStream Game Pad
Contollers
Depend of the game, if the game need a DualShock 2 the ps1 controller is not compatible. Check in the box of the game. "DUALSHOCK 2 Required"
If you play a ps1 game in ps2 is 100% compatible.
Dec 12, 2007 | Sony PlayStation 2 (PS2) Console
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
507 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
