Question about Zebra Z4M Printer
Z4M printer suddenly running in reverse
Printer was working fine. Went to print second batch of labels of the day and the printer started running in reverse. We haven't touched the machine, changed labels or ribbon between the label batches. I have had everything on & off, disconected the printer cable but it still mostly runs the wrong way. Ocassionally when first turned on it will feed in the right direction a couple of labels then go back to reverse.
  • derek24 Mar 17, 2009
    Thanks for this info, a new power supply board is a bit pricey so I will try for a second hand machine.
  • 155 Answers
The problem is in the power supply board and must be replaced. What fails is the chip stepper motor driver.
Posted on Mar 16, 2009
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
Zebra Z4M won't print whole label
Did u try system restore?It will restore all of ur settings to how they were when it was working...
Oct 08, 2007 | Zebra Z4M Printer
The printer will print one label correctly, then feed out a blank one. when the next label is printed, the printer reverse feeds the blank label into the printer to print the next one, but not far enough...
This sounds like a size issue, meaning that your label has too many lines and that kicks to the "next page".
Look for too many line items on first label.
Oct 06, 2010 | Zebra Z4M Printer
Z4M printer when printing on a 3.75 wide label the left side prints fine and the right side is missing half the print. Also continuous wrinkles in the ribbon causing gaps in the print. I tried different...
There is a tensioner that holds the printhead assembly down, slide it more to the right. It sounds like you just need a bit more pressure on the right hand side of the printhead.
Sep 28, 2010 | Zebra Z4M Printer
Z4m printer will miss labels in jobs. I've saved the job in the spooler and if I resend the jobs the blank labels will print out so I know the job is good. Any suggestions welcome.
Check the label size is set correctly in the application. Try using a driver from Nice Label or Seagull Scientific websites to suit Z4M (Not Z4M Plus). Recalibrate the printer and try again. Remember to setup the driver correctly because the driver will override the printer settings.
Nov 30, 2009 | Zebra Z4M Printer
My Zebra Z4m plus start to print in middle of the label,but suddenly to appear next message. error de papel.and stop the machine and the print on the label is in wrong positions
The label is not calibrated. Press keys FEED, PAUSE and CANCEL, turn the printer and release the keys when making the labels. Also verify that the type of material is NOT CONTINUOUS.
Roberto Martinez
Sep 28, 2009 | Zebra Z4Mplus Label Printer
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Slow Printing on Zebra Z4M
An unorthodox solution is to install an old driver. Another solution is to use with Codesoft the driver from www.seagullscientific.com, and with Zebra Designer, the Zebra Designer driver. If the printer is connected to the serial port, speeds up communication.
Roberto Martinez
Mar 30, 2009 | Zebra Z4M Printer
Printing problem
better to send it for repair
Apr 03, 2008 | Zebra Z4M Printer
Zebra Z4M Plus
this is a color printer or not
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra Z4M Printer Logo
220 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
