Question about NEC VT670 Multimedia Projector
Infocus ls 110 power ballast broken
Took it in for repairs and found out infocus no longer stock part 510-1532-00. i need to find a power ballast or find out if it can be fixed.
4 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: infocus ls 110 how can i open unit to perform
2 screws on the bottom left, one screw on the front (left side of the grill), the grill comes off exposing 2 more screws, then the tops opens from the left.
Posted on Jul 17, 2009
projdoc
  • 2237 Answers
SOURCE: InFocus IN76 Power board failure
through infocus or an authorized service center. try this place: www.avsolutionsny.com they're really good
Posted on Oct 20, 2009
projdoc
  • 2237 Answers
SOURCE: where can I purchase a new board from for my
Posted on Feb 03, 2010
Testimonial: "Thank you very much for your advice. We will be buying the replacement board for our infocus thanks to you. "
The old lamp in my in focus LS 110 reached its maximum hours. I replaced with a new lamp but it is not firing up - i think I need to reset the lamp hours but don't know how and don't have the...
Sorry, I am not familiar with the Infocus LS 110 but the user guide can be downloaded at
http://www.retrevo.com/support/InFocus-LS110-Projectors-manual/id/1081dj697/t/2/
You don't need to put in your email address but you will need to type in the numbers. It come in a PDF format so you will need adobie acrobat to read the file. It should have instructions on how to reset the lamp hours.
Hope this helps
Aug 01, 2011 | InFocus LS 110 Multimedia Projector
I have a infocus IN35 that at 100 hours burnt out a bulb. Thinking that it was just a bulb problem I bought a new bulb and it lasted 20 minutes. a t.v.repair shop said its probably the ballast that is the...
It is not a common problem. Ballasts rarely need repairs. Have you reset the lamp hours to zero after installing new bulb? If, yes to confirm about ballast please ask the TV repair shop man whether previously he had repaired any DLP projector. There is lot of difference in technology of DLP projector & TV (except DLP Projection TV). The problem could be in the projector main board. The lamp lights after getting Lamp ON signal from the projector main board. As the lamp ignites the ballast sends the signal of Lamp Lit. If the projector board senses that any blower/exhaust fan or colour wheel is not running then it will send a signal to Switch OFF the lamp. If you are tech-savvy then do as follows to check about lamp & ballast. Remove 5 pin connector from the projector. Connect projector to mains supply. Get a 5V DC power supply. Connect +ve to pin 3 & -ve to pin 4 of the ballast connector from this supply. The lamp should light. If it does not light then there is problem in the ballast (if the lamp is new). To give a chance you can check it for your lamp which lasted 20 minutes. Generally ballasts are made by OSRAM. You can get the ballast from OSRAM dealer. You will need the part number for that. Take out the ballast, it is there on it.
Apr 14, 2011 | InFocus IN35 Projector
What does a lamp bulb look like when it is no longer good or working? does it look burnt out? Mine looks like nothing it broken or burnt, but my projector isn't showing a picture on the screen. the fan...
look at the lamp head on. an obviously bad lamp will have cracks in the mirror, the stem can have frosty,veiny looking blisters or bubbles, the mirror can have lots of bubbles. And sometimes there are just no obvious signs.
Jun 14, 2010 | InFocus LS 110 Multimedia Projector
Screen goes blank and projector shuts downafter about 10 minutes (IN24 In Focus projector)
ballast/ power supply issue. you'll need to send it in to an infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 28, 2009 | InFocus IN24 Multimedia Projector
Infocus lp420 powers on (can hear sound) but no
if you get no leds, it's the power supply. if you get fans, it may be the colorwheel. if the colorwheel is ok, it's the ballast.
Nov 28, 2009 | InFocus LP400, LP420 and LP425 (Not z)...
InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Jun 23, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
I have an LP530. Need main circuit board
Try LumenArc. They stock a range of ballasts. If yours is not listed, then email them.
May 09, 2009 | InFocus LP 530 Multimedia Projector
Ballast
you have to go to an infocus authorized service center. you may be able to purchase it from them without having them put it in. check the infocus website for an asc. but for reference, the part # for the ballast/power supply is 520-0126-00 if there is a "0" in the 5th to last position in the serial #, and 520-0143-00 if it's an "a" in the 5th to last position.
Sep 29, 2008 | InFocus X1 Multimedia Projector
InFocus LP650 will not come on
That color is not listed because it is either Green or Red. There is no Blue, if you are getting Blue, you have something that is extremely unusual.
Feb 16, 2008 | InFocus LP650 Projector Lamp
X2 board
ebay has several that need bulbs... just a thought here is one of the item numbers Item number: 270207032811
Jan 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
NEC VT670 Multimedia Projector Logo
332 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
