A four or five? yr. old Compaq presario 1692 (hand me down) will not power on once turned off...it is also very hard to turn off once it's safe. The on/off button seems 'flimsy'? It seems dead? No lights come on at all. Do you think it's due a battery?
  • Joan Dillon Mar 10, 2009
    I'm hoping it's just a bad switch. Thanks for you help! :)
    If that's not it...I'll be back. ;)
  • 530 Answers
Hi im josh in cebu phils. may i help you?
Friend base from my experience in such stuff the problems you have mentioned always center at the push button problem. The dome behind the button is damage cut or dislocated or sometimes break and also the small spring dis aligned if there is a spring. it depends the model of the laptop. but as what i had experienced it is just the button of ON/OFF. to solve such problem you may go to the laptop service center near you and ask them for assistance or let them do the job. that's all friend hope i helped you.good luck
Posted on Mar 10, 2009
How do i install windows vista off of my compaq resario 1692 laptop that has windows 98
How do you install Windows 7 on your Compaq Presario 1692 Notebook PC, that currently has Windows 98 on it? (Win98SE?)
I would NOT.
Reasoning?
Primer:
Drivers are small pieces of software that allow the Operating System, to communicate with a device.
Windows 98, Windows XP, and Windows 7, are some examples of an O/S. (Operating System)
The optical drive (CD/DVD drive), audio, (Sound), graphics, and Ethernet, are some examples of a Device.
Let's go to HP Support, and look at the drivers available for the Compaq Presario 1692 Notebook PC, (HP bought out Compaq),
HP Support > Compaq Presario 1692 Notebook PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=95231&lc=en&cc=us&dlc=en&lang=en&cc=us
In the list click on the blue - Software and Driver Downloads.
(Don't believe we can use the Ampersand on here. That's why I used -
and )
Takes you to this page,
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lang=en&lc=en&product=95231&
On this page you are asked to choose your Operating System.
In the rectangular box that has - Select - in it, go to the right of the box, and left-click on the blue down arrow.
In the drop down list you will see that Windows 7 is not listed.
This means there are no drivers for your laptop, and Windows 7.
There have been many people caitlynbrean, that have installed Windows 7 on their computer, only to find that it will not work.
Sorry it couldn't have been better news.
Regards,
joecoolvette
May 13, 2012 | Compaq Presario 1692 Notebook
I have a problem with either the battery or my charger on my laptop compaq presario 1692. i would like to know which one of them is the problem?
Remove the battery from the laptop
Connect the charger and turn on the computer
If you have a bad battery, your computer will turn on
If you have a bad charger, your computer won't turn on
Jul 24, 2011 | Compaq Computers & Internet
Opertaing system not found
Your hard drive may be faulty, this is why the Windows operating system not found.
Go into the BIOS and see if the hard drive is detected, if not reseat the hard drive and boot up again.
If the Windows operating system not found then most likely the hard drive is faulty and to get the Notebook working again, replace the hard drive, install Windows on the new hard drive plus the Compaq Presario 1692 device drivers and your programs.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Jul 14, 2011 | Compaq Presario 1692 Notebook
I need the Compaq Presario 1692 quick restore cd iso (Compaq quick restore), if does someone could help me I´ll thnx
You will most likely have to call Compaq and get the replacement cd's. They are $4.95 plus shipping, Im sure.
Oct 08, 2010 | Compaq Presario 1692 Notebook
Memory and harddisk upgrade for compaq presario 1692
Compaq has a upgrade tool you can use for this ... find it at www.compaq.com/support
May 30, 2010 | Compaq Presario 1692 Notebook
Remove hd compaq presario 1621
I think it is the same as HP. When you undo the cover just pull it right out by the small plastic. No screws holding the drive.
Apr 21, 2010 | Compaq Presario Notebook
I have a Compaq Presario Notebook 2100 when I turn-on it appears the following."disk failed and "operating system not found" what i am suppost to do. please help... Thanks a lot
You can go into the Bios by pressing F2 on startup and see if the hdd is detected there or not, you can make the bios default by pressing F9 and then F10.
If this doesnot works you will need the ricovery disc and you will have to boot to windows recovery console and there Use the fixmbr command in the Windows XP Recovery Console to repair the MBR of the startup partition.This should hellp you to fix the problem.
Mar 10, 2010 | Compaq Presario 1692 Notebook
Compaq presario v6719nr wont turn on it was working but I did a hard reset and now it will not power up battery had showen good charger only light to come on now it the connection to the ac power feed
so if wont turn on with or without the battery is it, does it try to turn on, (makes a sound and lights turn on then turn off) if so it sounds like hardware failure, a hard reset shouldnt of killed it because it deals with software, not harware
Dec 31, 2009 | HP Compaq Presario V6000T Notebook
Compaq presario 2100 laptop operating system not
On my Compaq Presario Windows 7 laptop, I have got "Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
Oct 10, 2009 | Compaq Presario 1692 Notebook
Compaq presario 1692 laptop dvd-rom
Is this the kind of drive that can be removed from the laptop? If so remove it and then re-insert it.
Aug 08, 2008 | Compaq Presario 1692 Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
