Question about Dell Pentium 4, 2.26 GHz (1W391)
Monitor working properly but it sounds continously,very noisy
When i turn on the computer the monitor starts working after some seconds starts continous noisy sound hoe can solve it?
  • 530 Answers
Hi im josh in cebu phils.may i help you? Friend try this solutions:
Problem: Your Monitor Doesn't Display—The System Unit Issues a Series of Beeps Your PC uses beeps to communicate with you when something is wrong with the video setup. Check the settings on your video card to make sure that they're correct for your system. Also check any switches on the motherboard to make sure that they're set up correctly for your type of video card. (You should consult your system's instruction manual for details on this procedure.) Check to make sure that your video card is seated properly in its slot; you may even want to try inserting the card in another slot. If none of these suggestions works, try a new video card, or have your system examined by a professional.
In a pre-Windows 98, system, if you have two video cards installed at the same time, they can sometimes interfere with each other and cause neither to work properly. Try removing one of the cards; if this results in the remaining card working, you need to reconfigure one or both of the cards to better work together. (With Windows 98 and later you can install two video cards to run multiple monitors simultaneously.)
Problem: Your CRT Monitor Doesn't Display—It Makes a High-Pitched Whine This whine indicates that your CRT-type monitor, for some reason, is operating at the wrong frequency. Turn it off immediately—this problem could seriously damage your monitor! Now check the settings on your video card. Chances are that it's set to a higher resolution than your monitor is capable of displaying. If this isn't the problem, your video card itself could be defective. If your video card is okay, your monitor might be defective.
Problem: Your CRT Monitor Pops and Crackles and Starts to Smell Like the rest of a computer system, monitors can get dusty. When dust builds up inside the monitor, it can generate static charges.
It's also possible that the power supply inside the monitor has become defective. If the monitor demonstrates these symptoms, turn it off immediately and take it to a repair center. The technicians can either clean your monitor or replace the power supply if necessary
You may visit your monitor services center if the problems stills occur after performing the solutions mentioned. hope i helped you friend good luck
Posted on Mar 10, 2009
What causes a Syncmaster 2253LW monitor to start ok and immediately fade.
The monitor may be failing. Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 01, 2014 | Samsung SyncMaster 2253LW Monitor
My samsung Tablet's Screen keeps flickering continously
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 07, 2014 | Computers & Internet
LG CRT monitor continiously swith on & off, also no display on screen, CPU is fine & also not in power saving mode.
try unplugging the monitor and letting it rest for a couple minutes. If you have another computer please see if the problem is the same when the monitor is hooked up to that one.
Mar 27, 2013 | Computers & Internet
Monitor power light blinks on and off continously, no picture
Get a known good working monitor and hook it up to your computer and turn on the monitor and the computer, if you get video then you know the original monitor is bad.
If you don't get video from the known working monitor then you know that the computer is the problem.
Sep 03, 2009 | Dell E176FP 17" LCD Monitor
Monitor light flashes green and screen is blank
Best thing to do, hook up another known working monitor to the computer and this will verify that the computer is working properly.
If you get video on the known working monitor when you turn on the computer then you know the computer has a problem.
Aug 27, 2009 | Computers & Internet
Switch led is continously blinking in green colour
Sounds like you don't have a stable connection. Try shutting down PC, and disconnect the monitor, and reconnect it, and turn PC back on, then turn the monitor on...
May 14, 2009 | Hitachi CM621F (White) 17 in.CRT...
Dell Monitor comes on but no picture
The monitor isn't getting a signal from the computer, which is why the power indicator goes orange. There are two possibilities:
1) The computer isn't operating correctly. It may not be starting up at all when you turn it on, and you have a "no boot" problem to solve, or
2) The computer is working properly, shows all the signs of normal startup (hard drive activity, Windows startup sound from speakers, etc.). but video isn't reaching the monitor. There may be a problem with the video card (or on the system board if it's integrated video). Or the monitor itself is bad and not detecting the video. You can test this by connectng a known good monitor.
Jan 16, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Monitor malfunction
Hi!
You might also try to connect another monitor, to check if has the same behavior. In this case the problem is generated at graphics card or from loosen cable connections.
Jan 06, 2009 | LG Flatron L1715S 17" LCD Monitor
Noisy sound from monitor
Go through your menu settings on the front of your monitor and see if your able to change your display timings. Also go in to your display settings and change the hrs.
Feb 18, 2008 | Computers & Internet
The picture disapears, though the monitors stays on - every few seconds
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Oct 28, 2006 | BenQ FP71E+ (Black, Silver) (Silver,...
Computers & Internet Logo
90 people viewed this question
Alun Cox
