Question about Canon Office Equipment & Supplies
Canon ir1022 - How do I do a self test? - I need to know the IP address of the printer for remote support.
5 Suggested Answers
  • 53 Answers
SOURCE: Changing a Dell 3010cn IP address and Storecenter
Print a settings page from the printer. If you are not sure on how to get the settings page, download the user manual from support.dell.com, there should be instructions in there on how to get this. Once you have the settings page locate the IP address on the print out. Take this IP address (which may be different then the one you want to use) and open internet explorer, put the IP address in where you would normally type a web address, hit enter. This will take you to the embedded web server of the printer. Once you are there, you can look for printer settings, ip address or TCP/IP address. Once you have found this, you can set a static (meaning it will not change, unless you change it) IP address (the IP address your tech person gave you) and submit the information to the printer. The printer must be on and in the ready state for this to take hold. If you are prompted for a username and password for the embedded web server, dell default username in small case is admin, leave password blank or username admin, password is password. To confirm that the address has taken, print another settings page from the printer.
Posted on Nov 22, 2008
Joed911
  • 4338 Answers
SOURCE: setting Ip address on canon c3220 imagerunner.
Is the Canon connected with a cable that's connected to an active port. You can try to Fixed IP hold down 1 & 7 When you power up the machine, make the necessary network configurations and see if pings back with a reply.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 06, 2009
kakee
  • 1269 Answers
SOURCE: dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Posted on Jul 16, 2009
  • 108 Answers
SOURCE: How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Posted on Nov 25, 2009
Testimonial: "Thanks, Can you please advice how do i print network setup page from this printer [Cannon ir3570]"
Ip address
Click the Menu button on the printer and scroll to the Network settings to the IP address. You may need to change the IP address to suit your network.
Feb 26, 2013 | Canon MultiPASS MP360 All-In-One InkJet...
Canon IR 1023if; trying to network with buffalo router and two laptops and a wireless desktop. subnet mask 255.255.255.0 default gateway is 192.168.11.1 laptopA 192.168.11.2 laptopB 192.168.11.4 desktop ...
Did you change the coper to static IP? If not then the copier is most likely still set for a dynamic IP. A dynamic IP means the number will change from time to time when the IP lease from the router runs out. Your computers are most likely set for dynamic also. This is not a problem and the use of dynamic IP's is very common.
If you print out a status page (also know as a configuration page) from copier/printer there should be a Host name listed along with the IP address. The host name is a name that always stays assigned to the network card (providing you don't manual change it). If you substitute the host name for the IP address when you are setting up the printer port the computer will always look for that name on the network when you send a print job.
The IP address and host name are both ways to find the proper device you are looking for on a network. Think of them the same way as a phone number. You dial your friends cell phone and it goes out over the cellular network looking for your friends cell phone once it finds your friends cell phone his phone rings. IP's and Host names work the same way.
Let me know if you need anymore assistance. If needed I can log in remotely and give you a hand.
Shawn
Jan 28, 2011 | Canon imageRUNNER 1023iF Black and White...
Imagerunner 210S. I have a network card in this used printer but my computer does not see it. How do I install this printer on my home network? Is there an adapter to plug into the ethernet jack to...
  1. You need to set a Static IP address in the printer:
  2. Press the "Additional Functions" key on the Canon Imagerunner 210N keypad.
  3. Tap "System Settings" and enter your administrative ID number and passcode if prompted.
  4. Tap the "Network Settings" button and tap the button next to "TCP/IP Settings."
  5. Press the "IP Settings" button.
  6. Highlight "IP Address" and use the keypad to enter the IP address you want to assign to your Canon Imagerunner 210N.
  7. Fill in the "Subnet Mask" and "Gateway Address" fields with the appropriate information.
  8. Press the "OK" button to save the network settings and enable the new IP address.
Read more: How to Set the IP Address on Canon Imagerunner 210 N ' eHow.com http://www.ehow.com/how_7427700_set-canon-imagerunner-210-n.html#ixzz19ZSyEw8N Then install the driver and poit them to the IP address.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 30, 2010 | Computers & Internet
Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | HP LaserJet 1022n Printer
Canon image runner c3100 switched to dynamic ip addressing on new router but now ir c3100 does not work , i gave the printer an ip address and i can ping it from my computer and when i send print packets...
ok... turn dhcp on on the cannon... then turn it off and on... the cannon should pull the right settings... then turn dhcp off... and change the ip to the one you selected... all should be well after that... if it isn't... then you need to find the IP range of your router and get an IP address below it or above it.... say your IP address range is from 192.168.1.100 to 192.168.1.255 then you want an IP address below 192.168.1.100
Dec 16, 2009 | Canon imageRunner C3100 Copier
Canon imagerunner c3100n Howe do I remove
Your in the copiers IP address into your web browser and go to address book and delete address , you can also add address's here. If you do not know IP address, go to machine, touch additional functions, system settings, network settings, tcp/ip, IP and write down #.
Oct 30, 2009 | Canon imageRunner C3100 Copier
How to configure imagerunner c3100 as a printer on a network
what do you need to know?
you need to put a static IP address or set it to DHCP and load the canon print driver.
you need to create a tcp/ip port on the ip address of the copier
Aug 22, 2009 | Canon imageRunner C3100 Copier
How to find IP address
Print the config page, is the easiest way -Carl
Jun 23, 2009 | Canon imageRUNNER 1023iF Black and White...
Setting Ip address on canon c3220 imagerunner.
Thanks, Joe
Jun 06, 2009 | Canon imageRUNNER C3220 Printer
Printing connected ethnet set ip address wil not print
Go into Additional Finctions, select Network Settings, input IP Address, or select DCHP. Connect to PC or network. Download relevant printer driver. Switch photocopier on/off. Everything should work ok. Let me know?
Nov 30, 2007 | Canon imageRUNNER 2200
932 people viewed this question
old marine
old marine
