Volume stuck on low. When you slide the control in desktop tray up yo can hear sound but the slider returns to minimimum setting. New MSI amd mainboard. Windows xp pro. I have tried removing sound drivers that came with the board, cleaning registry and cache files, then reinstall. Can't seem to fix it.
  • tdo1960 Mar 10, 2009
    I already updated all drivers on the board before this happened.All windows updates video card updates etc. I build computers so I am not totally clueless. I always keep all drivers, win updates, direct x up to date. I also clean cache, cookies, spyware and registry at least daily. I was playing warcraft when it quit. I ran their repair utility and even removed the game from my drive to see if that helped. no luck.
  • 19,396 Answers
If your audio adapter stays only on low volume, even if audio settings are correct, and reinstalling updated drivers did not help, then the audio adapter is faulty.
For about $20 you can buy and install a replacement PCI audio cards with far better performances that the built in audio adapter:
Creative Labs Sound Blaster Audigy SE PCI Sound Card
Do not forget to leave feedback on the solution.
Thanks.
Posted on Mar 11, 2009
    Brigadier General:
  • 5,158 Answers
Try unplugging your sound device... reboot... adjust the sound... then plug your sound device back in
Posted on Mar 10, 2009
  • Roberta Smith
    Roberta Smith Mar 10, 2009
    also go into your device manager for sound... and make sure your sound device (onboard) is selected... you may possibly have the sound turned off in your bios as well
  • 10,515 Answers
Check for any other software that is running and set to 'mute'. The slider only displays the status of the volume mixer device, and the device itself is shared between all the programs - if any of them changes the volume, others should move their sliders accordingly (if they don't, it means they are sloppily written.) If one program keeps muting the volume, setting it in another won't help.
Also check if (if you have a laptop or a multimedia keyboard) the 'volume down' key isn't stuck. Thanks.
  • 6,487 Answers
If you an use a updated driver for the audio device that will be good so we can see if this is only a problem with the audio driver of the unit...
  • Mark Gil
    Mark Gil Mar 10, 2009
    If all those failed already I rather do a repair for your operating system to make sure this is not a problem with the computer system itself...
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
No sound after installing win 7
Dear user,
maybe Windows 7 is not compatible to the specification of your hardware. It is better to return your previous Operating System
May 15, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Volume control is missing
I am going to guess that you are talking about the volume control button on the bottom right hand side of the screen right? Did you recently install a new operating system or upgrade? No worries either way! Returning the volume control slider to the bottom right hand side of the screen is an easy task. I will walk you through it.
To return the volume control to the desktop screen, we need to go into the control panel. If you already know how to get to the control panel, please go there and find the ICON that says "sounds". If you don't know how to get to the control panel, follow these steps:
(Please note that the instructions below are for a person with the classic taskbar set up only)
Go to start at the bottom left side of your screen and click on it. Then slide up to "settings" and move to the right until you see control panel and click on it.
In the control panel, locate the ICON that says "sounds" and click on it. You will find the volume control option locate here. Make sure that sounds are enabled. You should see a choice in your current scound sceme that says something like "windows default" or similar.
Hope this helps?
Dec 06, 2010 | Microsoft Windows XP Home Edition
My polk audio speakers from a prior hp computer are very, very quiet on my new compaq system. what can i do?
The audio setting in your new computer is set to low level. Right click on the speaker button at the right hand bottom corner of your task bar,Then open the volume control from there. push the slider up in the volume control and also on the wave.You can push the slider up for the CD player as well as PC speaker also if any of these are also kept at a low level. If you do not have a speaker icon in the task bar, open control panel,(click on start and you will see the control panel selection, double click on it) and double click on sound and audio devices. Under device volume, push the slider from low to high. while you are here you can click on "place volume icon in the task bar" You can also click "advanced" and select the appropriate speakers here, like desktop stereo speakers or surround sound or whatever suits your speaker. click ok to save this and that is it.
Jan 22, 2010 | Extech Instruments Circuit Breaker Finder,...
Logitech Quickcam: Recording Level slider moves uncommanded
There is one more mic control you are forgetting. In the system tray you have a volume control. When you click it open you would come across another Mic control that slides up and down try using this one. I feel that if you use two of these the handling may become a little easier. Let logitech's control be constant and use this one to handle the speech contents.
Dec 09, 2009 | Logitech QuickCam for Notebooks Pro...
Can't hear recordings
Try double clicking on the volume control in the system tray.
In the box that comes up, see if the wave control is off, or set low.
Move the slider up, you should get sound.
May 04, 2009 | Sony Sound Forge 8.0 for PC
VOLUME TOO LOW ON COMPUTER, HOW DO I SET VOLUME , SO THEY ARE LIGHER
On Vista 64bit version goto control panel>>Hardware and Sound.. under sound click on Manage Audio Devices>> then select your speakers by double clicking on them. In the new box that comes up goto Levels and there are slider bars for all settings - top one is Audio output. Slide this to the right. Mine was set at virtually zero when I plugged my speakers in yesterday.
Mar 29, 2009 | ViewSonic NeoSat SP2104 Computer Speakers
Hp Pavillion a1140n suddenly has very low sound...
chances are this is a windows sound setting. in the system tray (bottom right by the clock) right click the speaker icon and select 'Open Volume Control' you will see a series of sliders. Check and make sure none are set low. about 3/4 up for each should be fine.
Other things to check:
Speaker Cables, Speaker Volume, power to speakers.
Jan 08, 2009 | HP Pavilion a1140n (PX774AA) PC Desktop
No sound on my computer
If you are using windows then double click on speaker icon in system tray near TIME display.. it will open a window, now see if there is a check box marked as MUTE or volume level set to low (in Master Volume & Wave ).. Un-check if mute is selected or level up the volume slider... if there is no icon then use control panel to go for sound settings.. if it say No Device then use your computer driver CD and install sound driver and restart your PC... please inform if it does work.
Plese Rate Me.. Thanks.
May 13, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
