Access sql database using C.
I want to access sql database by using C language. which i want to furter use in WINCC.
  • 156 Answers
Please go for the ORACLE 8i or higher, it has a utility called proC, in proC you can create program to access any database in Oracle or SQL server.
After compiling program in proC environment, it will create C code for tha same logic, that you can compile and use in C enviromnent
goodluck
Zulfikar
Posted on Mar 21, 2009
What is SQL?
It is a special purpose programing language. Computer language you will never use, unless you are into servers or programing type software
Jan 27, 2015 | Oracle 10g Database Standard (ODBSEONUPP0)
Which database can I use with ColdFusion?
ColdFusion supports ODBC-compliant databases. With Net Nation's ColdFusion plans, you can use a Microsoft FoxPro, Microsoft Access or Microsoft SQL Server database. ColdFusion supports both DSN and DSN-less connections.
Oct 09, 2014 | Oracle 10g Database Standard (ODBSEONUPP0)
What is .sdf file
The .sdf or standard data file is used for storing data in a structured format; uses fields of fixed lengths to store values; can be imported and exported by various database and data analysis programs; commonly used for transferring data between different programs.
Sep 03, 2011 | Oracle 10g Database Standard (ODBSEONUPP0)
How to connect c++ program to database
In order to use MS Access or any other SQL database you need to learn the SQL language -- or at least have a basic understanding of it..
Mar 12, 2010 | Microsoft Mlf Visual Studio Enterprise...
Steps in saving file in excel to database
severals solution :
- save file as text separated by comma and use sqloader from oracle
- use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
- use ODBC from MicroSoft
Dec 11, 2008 | Microsoft Computers & Internet
SQL 401: cannot open database
SQL database Recovery Software remove errors from SQL server database and allow recover your all database of SQL Server 2012 or below versions. The software support with all over version of SQL server. Try at here:-
SQL Database Recovery
Jun 06, 2008 | Computers & Internet
Inserting value by clicking a RadioButton
Please let me know in which language your are want to use radio button to put your datas into database & please mention the database you are using, like access, sql etc
Feb 14, 2008 | Computers & Internet
SQL server won't work on my laptop
Two ways to access your server. First, make sure the SQL Server Service is running. Start | Run | Services.msc | Enter. Look for Microsoft SQL Server Service and that it's running. Or Look for the SQL Service Broker icon by the clock and see that it's running. The default instance of SQL Server uses the Hostname. Start | Run | Cmd | Enter. The type hostname. This will be the name to access to server. Then type IPCONFIG, this is then the IP address that you could also use to access it.
SQL Server runs on port 1433, so any firewall has to have it open.
Open Query Analyzer, type in the hostname or ip of the local box, type in "sa" and the password for sa (if setup in mixed mode) or Windows Authentication.
Once you login in, you should now see the databases in the Tree on the left side under the Server | Databases node.
Your description though states "SQL Server won't work on my laptop". TO answer this, the only two SQL Editions that work on anything other than "SERVER" software is SQL Professional and SQL Developer. All others have to be on a "SERVER" platform.
Aug 30, 2007 | Microsoft SQL Server 2000 Standard Edition...
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
