Time saver light
Hi we oved home and cant find the manual the machine switchs on start washing then time save light comes on and thats it thanks lee chapman 07970424791
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
Hi, I have a Hotpoint WD440 Wash / Dryer. When switched on at the mains electricity the "Rinse Hold, Reduce Creases, Drying Heat, time saver, dry and on/off buttons all flash for approx 5 mins, then...
The flashing lights are an error code (Which I can't quite figure, but I believe ARE associated with a blocked filter. Is it possible that the slime and mess extended beyond the filter?
Before you go throwing the machine away, Unplug it from the mains (NOT just turn it off) to allow the machine to reset and while it's unplugged, stuff your garden hose up the waste water pipe and turn it on full blast to blow any remaining debris out of the way. (Wrap a towel over the end of the pipe to soak up the spliiage as one will not fit neatly into the other).
As the Dr Pepper ad says - "What's the worst that could happen?"
Jul 07, 2011 | Hotpoint Ariston WD440G Front Load...
Hi, I have a Hotpoint WD440 Wash / Dryer. When switched on at the mains electricity the "Rinse Hold, Reduce Creases, Drying Heat, time saver, dry and on/off buttons all flash for approx 5 mins,...
The 'capacitor' comments normally refer to the start capacitor of the main (wash/spin) motor and not the much lower power drain motor.
I would still concentrate on the blockage/ drainage which is what the lights refered to and you found (most of) the cause! Here are my complete and generic (pre-typed!) guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board- but I would be surprised)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 07, 2011 | Washing Machines
Have a whirlpool model LSS7233dq0 suds saver , the water will not the washing machine to the ash tub to save wash water, banging on side brings it into cycle I have already rplaced solenoid on the...
the diverter valve for the suds saver is faulty. Go to this valve and operate it manually to see if it is not jammed. THEN TRY IT ELECTRICALLY TO SEE IF THE SOLENOID PULLS IN THE VALVE. cHECK THAT YOU HAV e the cycle switches operated correctly too. Next see if there is power at the valve at the correct time cheers T
Jan 23, 2011 | Whirlpool Washing Machines
Hi, My washing machine, Fisher and Paykel, MW 511 PRIDE would not do the SPIN cycles. Please advise. Thanks. Sam Lee
Hi Sam Lee.Now , does the machine drain the water?If it does drain the water does it stop and beep and show an error code?if it does the error code will be a series of lights that will light up when the machine is beeping.They will be on a row of 8 lights.Starting from left to right which lights are lit when the machine beeps,Is it the 2nd and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 03, 2010 | Fisher and Paykel Washing Machines
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Dont want to save suds.( Kenmore model 5450290 Suds saver washer)
disconnect the wireing to the suds saver valve and tape the ends off.
valve will no longer open for the suds cycle
Jan 30, 2009 | Kenmore Washing Machines
No problem but what is timer save on wd440
Quick wash is normally used for clothes that are lightly soiled, and do not require a full wash programme,it has nothing to do with the amount of washing in the m/c.
Time saver cuts down on the actual length of the prog, by approx 1/3, there by saving time, again you would normally use this for washing lightly soiled clothing, it is only available on progs B-D and G
Plz rate my solution.
Thanks.
Jan 23, 2009 | Hotpoint Aquarius WD640 Front Load...
ON/OFF & Time saver Button keeps flashing
For mine, it started flashing the on/off light along with the "drying high heat" and the "reduce crease".
Unplugging the unit for 30 minutes appears to have reset the machine and it is now working.
Aug 18, 2008 | Hotpoint Aquarius WD640 Front Load...
AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Feb 25, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
