Question about Lenovo 3000 Y410 Notebook
Keypad problem in lenovo laptop
Actually my laptop keypad writes another words instead of proper writing some one help me to solve this problem
  • 530 Answers
Hi im josh in cebu phils.may i help you? Friend try to do this solutions it will help you.
Problem: You Type One Key, and a Different Character Appears Onscreen This is an interesting problem with four possible causes:
  • You really didn't type what you thought you did. Look at your fingers. Now look at the screen. Now look at your fingers again. Is everything the way it should be? Good!
  • If you have a programmable keyboard, you or someone else might have reprogrammed the keys so that they don't do what they normally do. Refer to the keyboard's manual for instructions about how to reprogram the keys.
  • If you're in a specific software program, some programs let you reprogram the keyboard from within the program. When you exit the program, your keyboard should be back to normal.
  • It's possible your keyboard is broken. Try hooking another keyboard up to your system and see how it works.
Problem: Your Keyboard Isn't Responding Properly What do you do if you hold down a key and it repeats too fast or too slow? Windows lets you make adjustments to your keyboard via the Keyboard Properties dialog box.
Just open the Control Panel and select Keyboard, and then select the Speed tab. Adjust the Repeat Delay and Repeat Speed settings to your liking, and then test your settings by clicking in the blank box and holding down a key. After you have things adjusted to your liking, click OK.
Problem: Your Wireless Keyboard Isn't Responding Properly This is the same issue as with a wireless mouse—your batteries are getting weak. Replace the batteries in your wireless keyboard to put things right.
It's also possible that you're experiencing interference with some other wireless device. Try moving your wireless receiver or the offending device, or turning off the other device while you're at the computer.
Just try these solutions friend. Hope I helped you Good luck
Posted on Mar 10, 2009
The numbers on the letters jkluio789 how do you use those? Thanks
Posted on Nov 19, 2009
Hello, when I enable my NumLock I can't write some letters, then it will instead of writing: L or O it will write 3 or 6. And I need to have numlock on when I am playing games because I have spells and...
Hi, If on the game options haven't got the option to chance actions to different keys, then there is only one thing you can do. Keep changing between NumLock and Keys. Its quick anyway. Hope this help. Thanks for reading.
Jul 11, 2011 | Computers & Internet
I am using Lenovo Y550 laptop. I want to use the Print Screen command but unfortunately there is no Print Screen key in this laptop. Could anyone please help me with regards to this issue. Thanks.
Most laptops do not have a dedicated print screen key, but instead have a function key (lower left of the keyboard, with some abbreviation of the word "function" on a key in a different color than the writing on the rest of the keys). Once you find the function key, look at the writing on the other keys that is the same color as the writing on the function key. One of those "other color" labels will be for print screen, and to use it, you hold down the function key at the same time as you push whatever key says print screen in the other color.
Jun 10, 2011 | Lenovo IdeaPad Y550 (41865GU) PC Notebook
Laptop keeps typing over words that i'm trying to edit
I presume you are using Microsoft Word for editing? At the bottom look and see if you notice the letters OVR. That means your editing function is set to over write. Just hit your Insert or INS key to make it go dim which means the overwrite function is disabled. Then try typing again. With the over write function disabled you should be able to type normally and insert words instead of over writing or erasing previous characters.
Apr 18, 2011 | HP Pavilion ze2000 Notebook
When i write jimmy for example it incorrectly
Hi there, At a guess I would say that the "Num Lock" is on, To enable/disable the keypad, press "Fn"+"num lk". cheers
Apr 02, 2010 | Compaq Armada 110 Notebook
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
I can not write words from its hardware keyboard in 8150 Ultimate
you need to change the input, usually hash or star on the keypad usually changes it to the T9 dictionary.
Sep 15, 2009 | i-mate Ultimate 8150 Smartphone
Write Message by Keypad
When you see soft keypad on screen while writing new message, click on the keypad icon at the bottom.
This should hide the keypad from screen.
Now you can type. The only problem is you can not type custom words. You have to depend on t9.
If you want to write custom work click on Add New word option. The word will be saved and t9 will recognize it when you try to type it again.
Sep 09, 2009 | ASUS P527 Smartphone
I have lenovo Y410 775754Q with problem of cd/dvd writing,read
Go to this link & I'm sure it could solve your problem... Trust me... :-)
http://www.laptops-drivers.com
Jul 11, 2009 | Lenovo 3000 Y410 Laptop
Cd write wizard
one reason may be that your writer may be old and the lense must have died.
another is that the lense require cleaning.
the last one is if you have sony writer then you need to upgrade the drivers and firmware for your writer which you will get here. if it is other make, search on google for its firmware.
http://sony.storagesupport.com/models/21
If all the above things dont work, replace it.
Feb 02, 2009 | Lenovo 3000V200 Laptop
Lenovo 3000 Y410 Notebook Logo
1,170 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
