You are not the only one. Many users have encountered iPhone stuck on updating or iPhone won't update issue. Don't be panic, the methods below might help you out.
Method 1: Make sure that there is enough storage for iOS 14 firmware. Navigating to "Settings > General > iPhone Storage" where you can see your iPhone storage. If there is not enough space, remove some apps or large data temporarily to get update continue.
Method 2: Connect your iPhone to power source and good Wi-Fi network. These two may affect your iPhone stuck on installing new firmware.
Method 3: Re-download the firmware. If the update on your iPhone does not finish, you can try to re-download the update firmware to finish the task. Navigate to "Settings > General > Device Name Storage" where you need to find the update firmware in the app list. Click "Delete Update" to remove firmware from your iPhone. Then, you can re-download the firmware again.
Method 4: Try to update in iTunes when iPhone stuck on installing via air. Connect your iPhone with computer and then launch iTunes. Click "Download and Update" to proceed the update process.
Method 5: Use some third-party software to fix iPhone won't update issue. Generally speaking, these kind of iOS repair software can fix problem like this. The principle is to reinstall the firmware through Recovery Mode and perform in-depth repairs.
If you still can't fix iPhone stuck on installing iOS firmware, you may consider it is a hardware issue. Then,contact Applefor further repair. If you need more detailed steps on fixing iPhone stuck on installing firmware issue, read on this tutorial for further reference:How to Fix iPhone Won't Update?
What's the current version of your iPhone?
iOS4? or you want your iPhone back to iOS4?
If you do not back up for IOS4, you won't update it to the version before iOS 6 now, as APPLE has stop support the Verification of old version
I your current version is iOS 4 and you want to update it you can update by iTunes easily. Just download newest iTune on PC and link iPhone to PC, then it will notice you for the update information.
