Question about Dell Latitude 110L Notebook
Display is very faint, disappears
My screen would be very faint at times after closing the notebook, and at times struggles to get back to full function. At times I will not have a problem, but have found that using an external screen sometimes fixes the problem
  • Dell Master
  • 32,281 Answers
If you see a dim image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 10, 2009
Replace the inverter board below the lcd panes  with same part number.if it is in india i can help you
Faint screen
Try using an external screen. If that is OK, replace the screen as there may be a hairline crack on the driver boards.
Apr 01, 2014 | Toshiba Satellite Pro L300 Notebook
My lcd does not display anything when turned on
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Feb 04, 2011 | Dell Latitude D810 Notebook
Display numbers/words disappear
There are two options for this model:
- You can order an exclusive modified display control unit (#CU440) with proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, you get a core refund of $30. It comes with a one-year guarantee. Details are here.
- Or your existing control unit can be repaired for $39.95 in most cases, also with a full one year guarantee. Details are here.
May 24, 2010 | Dacor DMT2420SS Microwave Oven
Lcd blanks out
Yes, that is one possibility. It could be the cable from the motherboard to the display. Inverters are fairly common problem.
May 14, 2010 | Toshiba Satellite 1805-S204 Notebook
Display only stays visible at lowest illumination
Sounds like your display's backlight is dying. Your scfreen is in need of replacement. The higher ther brightness setting the faster it quits working.
Sep 25, 2009 | Dell Inspiron 1100 Notebook
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
LCD screen is faint XPS M140
You backlight is failing. That is the bulb that provides the brightness to the screen. You need to replace bulb which is very tricky to do unlesss you have experience or replace the screen.
Please rate this if helpful.
Thanks
May 05, 2009 | Dell Inspiron XPS M140 Notebook
Fault on screen everything very faint
I stripped down the laptop to see if I could locate a back light bulb.
I removed and replaced the plugs powered the laptop back up and all seems to be working well
Thanks anyway
Dec 30, 2008 | Toshiba Satellite 1200-S122...
Dark screen
this is due to malfunctioning of the cable sending signal to the display panel replace the cable this problem will be solved
Oct 01, 2008 | Toshiba Satellite A15-S157 Notebook
Flickering screen and no display
thats the complaint of LCD inverter circuit...if u dont know to open it,then dont do any thing better thing is go to the nearest service center of toshiba and try to repair it if thats failed. u have to replace with a new inverter circuit.dont try to repair urself...thats all.
Dec 13, 2007 | Toshiba Satellite P25-S507 Notebook
Dell Latitude 110L Notebook Logo
234 people viewed this question
Alun Cox
