Question about HP Digital Sender 9250c scanner Printer
No admin button on hp9250c homepage to setup initial settings
How to find the password for my Belkin Router
While setting up your wireless router, you have to give in a password, if you want to setup a secure connection. The initial password for the admin account, is most of the time admin, but most routers have that printed on them. Check every sticker on it. Most routers you can set to factory settings, by pressing the reset button for more than 15 seconds. Most of the time that is on the router too.
If you already did setup a connection and you forgot the password, reset the router and set it up again.
Oct 25, 2014 | Computers & Internet
How to reset admin password for a xeror phaser 360 printer
Try this:
If you have set an admin password for CWIS (CenterWare Internet Services - your webGUI) then this procedure should reset that password.
  1. Press the Menu button on the control panel.
  2. Select Admin Menu
  3. Select Network Setup
  4. Select Reset Defaults
The other reset procedure is going to initialize all of the machine's NVM (Non Volatile Memory). Note: this procedure, and the one above, will not roll back the f/w on your machine.
  3. Select Maintenance Mode
  4. Select Initialize NVM
Taken from here
Sep 29, 2013 | Office Equipment & Supplies
How do I change language settings on my Dell V313 printer
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Printhead error
Apr 22, 2013 | Dell V313w AllInOne InkJet Printer
I cant reset password for my dlink 1155..dlinkap
Hello visit the homepage:
http://www.dlink.com/us/en/support
And download a user manual.
Or:
Resetting your D-Link router's Wi-Fi password is easy:
  • Type your router's IP address -192.168.0.1- into your Web browser.
  • At the login screen, select "Admin" from the drop down menu and enter your admin password.
  • Once you access the Web configuration screen, click "Setup" in the top menu.
  • Select the "Wireless Settings" link on the left-hand side.
  • From there, click on the "Manual Wireless Connection Setup" button.
  • Scroll down to the field representing my "Pre-Shared Key". If you don't see it, select a security mode from the dropdown menu at the bottom of the screen first.
  • Type in a new password. (I use a hybrid WPA/WPA2 security mode.)
The Forgotten Admin Password
If you forget your Web configuration password, you're stuck: you have no way to change any settings on your router. Your only recourse is to use a paperclip or other pointy object to reset your router to its factory settings. With the
paperclip, hold down the tiny reset button on the back of your router for about five seconds. Your router lights will blink to confirm the factory reset. You can now use the router's default password to log into its Web configuration screen (look in your router manual if you can't remember what this is). Once you're in, be sure to change this password to something unique.
Remember to save your settings when your done.
Good luck
Nov 24, 2012 | Computers & Internet
Router
Or:
Good luck
Nov 24, 2012 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I had a computer person set up our router before, but we have moved and now I want to set it up myself a different way. I want to have access to wireless internet. Initially I was able to put in the IP...
You probably disabled http and https admin. Locate the reset button on the back and hold it for 10 seconds. Reset maybe located in a pin hole on the back, use a pin or paper clip to press it. Refer to the setup doc for default user/pass. Typically admin/admin.
Comment back if you need further assistance.
Aug 31, 2011 | CP International WBR-3406TX Wireless...
I have a Netgear Wireless router n- wnr2000, how can i disable the macfiltering
You have to login to the routers homepage. To do this you need to go to you computer and open your internet browser. At the top in the address bar type 192.168.1.1 and hit enter. Then a login screen should appear. The username is admin and the password is either blank as in no password at all or it is admin or password. Once you login to the homepage go to advanced > wireless settings > click setup access list. Under access list you should see an option Turn Access Control On. Uncheck that option and save.
Feb 04, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
I'm forget admin password on hp 9250c. Please, how recovery admin password.
Cold reset for HP9250C
A cold reset resets the values of permanent storage variables to factory default. Often this is necessary
for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
Embedded Jetdirect IP address
SMTP IP address
LDAP IP address
Embedded Web server password
All control-panel configurable items
The following items are NOT cleared during a cold reset:
Local address book e-mail addresses
Real-time clock (date and time)
Page counts and maintenance counts
Product serial number and formatter number
Service ID
Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. Immediately after turning on the device, press and hold down the #6 key (do not wait for the memory-count). When the three status LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Oct 04, 2010 | HP 9250c Printer
Problem with Setup Wizard for Linksys 2.4 GHz Wireless-G Broadband Router
burn disk reset router unplug power. plug ethernet cord to laptop to router type 192.168.1.1. then admin
admin
now you should be forwarded to router setup check settings hit save then go wireless security choose wpa2 choose password has to be a word atleast 8 letters long plus numbers
Aug 30, 2008 | Linksys Wireless-G WRT54G Router
Dell Wireless 2350 Router
I can definitely help you on this, however, this would require us follow a few troubleshooting steps which cannot be dictated here. So, I would request you to initiate a chat session with me from the fixya homepage and we would carry on from there. Cheers
May 15, 2007 | Dell Wireless 2350 Router
HP Digital Sender 9250c scanner Printer Logo
213 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
