Question about Microsoft Xbox 360 Console
My xbox refuses to read games at all. everything works fine its just got a problem with reading discs. if i dont use any power on it for a few day than it works sometimes. it also doesnt say the disc is unreadable it just says reading then after a whil its says open tray and close tray.
  • 23 Answers
Sounds like the flash drive needs resetting its very hard lol
Posted on Mar 10, 2009
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
I am playing Modern Warfare 2 on my Xbox 360 and after about 20 minutes it quits reading the disk. Any clue on how to fix this? Other disks work just fine.
Check the disc for any scratches. Clean the disc with some disc repair solution. If you just purchased the game try and take it back to where you bought it for an exchange. If there is no scratches or anything that could stop the disc from reading right it could be your Xbox. Xbox has been known to have many issues with heat maybe your Xbox is getting to hot. In which case the problem is your Xbox and you will have to call Microsoft about getting a new Xbox. My Xbox started to go bad in the exact same way. I would play multiplayer for awhile and it would freeze after playing for a little while. I would then turn the xbox off for a few min then turn it back on and it would work again for awhile untill a few days later when i got the red ring of death which means a hardware fail.
Dec 26, 2009 | Video Game Consoles & Games
Xbox 360 not reading discs
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Nov 17, 2009 | Microsoft Xbox 360 Console
Disc Reader not reading disc
You can try to Clean with dvd cleaning kits...if doesn´t work..the only way fix is to disassemble the 360 and force the dvd laser adjusting the micro pot...located under the laser unit..But you will loose warranty and I think that the best way is to send your game console to microsoft...what hurts is that $140,00 you can buy 02 or even 03 xbox drives on ebay. Choose the best way! Good Luck!
Sep 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 not reading any games
well this is easy proably the disk is scratched or theres a problem with the xbox if it is under 30 days old bring it back and get another one at the store where you bought it
Jun 05, 2009 | Microsoft Xbox 360 Console
Cant read the game disc!!!
if you only had it for 5 months its still under worenty so call MS and they will fix it
Apr 14, 2009 | Microsoft Xbox 360 Elite Console
Game just stopped
The xbox 360 is to old or it heats up
May 03, 2008 | Microsoft Xbox 360 Console
Doesnt read discs
Whenever mine wouldn't read disks i'd hit it a few times on the top face (lower left side above dvd drive), then turn it back on to see if it would read it. Sometimes i had to do it 5-10 times... and eventually it worked again for a few months..... (of course, do this at your own risk, but it works for me)
if that doesn't work I'd Call xbox 360 support and see if they will fix it for free (they are fixing the 'flashing red lights" error for free right now... possibly your disc read error). if they refuse to fix it for free and you don't feel like paying...... then you may need to make it have the three red-lights
xbox support may be cover this issue.
Jan 09, 2008 | Microsoft Xbox 360 Console
360 game reading problem
ive got the problem to on some games eg. assassins creed just bought it, it keeps saying read disc error its not the disc its the xbox itself im gunna try and take it bk now.
p.s.the problem is with the memory unit on top.
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
61 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
