Question about Motorola Mobility H700 Wireless Headset
My h700 couldn't be switched on.i charged it for the first time when i bought it, flipped the boom,but no light came out from it.
    Problem Solver:
  • 15 Answers
I say bring it back to where you bought it. I have this same head set and have never had this issue.
Posted on Mar 12, 2009
For some reason, My Motorola H700 quit going into pairing mode? No matter what I do I can't get it to go into pairing mode. I have a Motorola Droid, and have had it connected to it before, but now it...
I have had this problem as well. Just to recap the problem. When you push the talk button and it turns purple, then you flip the speaker boom the unit starts flashing blue and will not pair. If this is the case then you should try unclipping the ear piece on the unit. Then repeat the pairing feature on the unit only this time hold the unit open with additional force. Not so much that you break the speaker boom, but enough to help the unit make a connection when it is flipped open. The problem with these units is that sensor inside does not always make a good connection especially after time and use. This should resolve your problem.
Curtis
Jun 04, 2010 | Motorola Mobility H700 Wireless Headset
Power won't come on
I am having similar issues. Before you OPEN the boom, press and hold the CALL button in the middle and ensure your Bluetooth is paired/synced with your cell phone.
Press and HOLD about 5 seconds until the PURPLE light illuminates. Then flip it open immediately and begin the pairing process.
My problem is that the purple light won't illuminate at all...
good luck
Jul 01, 2008 | Motorola Mobility H700 Wireless Headset
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
H700 will not turn on. NO LIGHTS
I have the same issue. Bought 10 new H700's and 3 of them will not turn on. Still trying to find a fix.
Nov 20, 2007 | Motorola Mobility H700 Wireless Headset
Connection problem
noavatar_s.png By nonexpert_s.gif Guest
Rank: Not rated
Rating: 0%, 0 votes
First, turn on your bluetooth on your phone.
Flip the boom mic on your H700 and hold down the call button for 5 seconds.
The indicator light should be purple. That means it is in pairing mode.
Then using your phone, attempt to connect to your H700.
It'll ask for a passkey. The default passkey is 0000.
Nov 08, 2007 | Motorola Mobility H700 Wireless Headset
My Motorola h700 bluetooth will not pair
Rest assured that the drop did not cause this.  There is a general problem with these H700's.
Press the multifunction button until the led turns purple.  Keep it pressed in while you flip the arm open.  The arm needs to be kept fully extended to keep it in pairing mode.  If you succeed in positioning the arm correctly, a steady blue light will be on.  If the light goes off...close the arm and try again.
While in this mode...execute the pairing procedure from your phone...it should find the H700.  The default key is "0000".
Oct 18, 2007 | Motorola Mobility H700 Wireless Headset
My headset wil not turn purple after holding it for 5 seconds
You need to hold down the call button before opening the mic. Once it turns purple immediatly open the mic. If you wait too long to open the mic after it turns purple it will turn blue or just go out.
Aug 26, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
90 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
