My h laserjet 4250 dislays an error code 13.01.00 in tray 2. i've tried solving the problem but could not. i need your help
    Genius:
  • 2,120 Answers
Swap the feed rollers around, pinch blue tab and pull off
Posted on Mar 10, 2009
Laserjet 4250 error 59.00
I've found this specific error code leads you to a main motor failure, Ive found some decent priced motors if you need them: HP 4250 Main Motor
Aug 30, 2011 | HP LaserJet 4250n Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
I am getting 60.02 error on my HP laser jet 4250 printer
this error comes from tray 2 lifter assembly check the wires harness of motor sitted properly in dc controller pcb
Sep 21, 2010 | HP LaserJet 4250 Printer
My hp 4250 laserjet printer displays an printer error 57.4 message when i switch it on. what could be the problem? since it can not continue the printer checkup progress.
<P><A href="http://www.printertechs.com/tech/error-codes/error-codes-index.php">http://www.printertechs.com/tech/error-codes/error-codes-index.php</A></P><P>&nbsp;</P><P>Plz check the the link for the detail error codes.</P>
Aug 28, 2010 | HP 4250 Monochrome LaserJet Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
13.20 error on tray 2 of HP4250
Paper in the back of printer where the duplexer is. Could also be the fuser is going bad.
Jul 23, 2009 | HP 4250 Monochrome LaserJet Printer
Error 60.20 hplaserjet 4250
Issue
After powering up the printer, a 60.2 error is displayed on the control panel. Even after power cycling the printer, the error does not clear. This error indicates that tray 2, and the lifter-motor for tray 2, are not functioning.
Follow the steps in the Solutions section before changing the lifter and DC Controller PCA.
Solution
Complete the following steps, testing the printer after each step to determine if the issue has been resolved:
  1. Turn the printer off and then power it back on again.
  2. If the error persists, turn the printer off.
  3. Verify that the tray 2 lifter wire-harness is fully seated in its connector on the DC controller PCA. Test the printer.
  4. Check the tension of the spring in the lifter. If the tension is not correct, replace the spring (RC1-0198-000CN). Test the printer.
  5. Replace the tray 2 lifter-driver assembly. Test the printer.
  6. Replace the DC controller PCA. Test the printer.
Jun 07, 2009 | HP LaserJet 4250dtn Printer
HP 4250 down (paper jam without paper)
hi,
the fuser of that unit is in the back, you can saw it by sliding out the back cover. you can pull it by unlocking the 2 lock on side of it..
try to locate the sensor of the fuser assembly.and also try to see if they pick up very well both tray 1 and tray 2..
hope it would help you..
Aug 05, 2008 | HP 4250 Monochrome LaserJet Printer
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
753 people viewed this question
jasbo
jasbo
