By Jimmy NY - usenet poster
I have a panasonic stereo that uses bi-wiring to connect to its 2
speakers. i have a speaker selector that only allows 2 wires per
speaker and i want to hook it up to my stereo and other normal
speakers. can i do this. if so how?
Solution #1
posted on Aug 02, 2007
paulrmc - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Horribly unlikely. Panasonic still has engineers on staff, and other than
their high-end weirdness, no way would bi-wiring show up in a mid-priced
stereo system.
If there are 4 wires going to each speaker, the smart money is on bi-amping.
If the speakers are bi-amped, then applaud the sophisticated engineering of
the system, and realize that upgrading its speakers is practically
impossible.
You bought an all-in-1 solution to a certain problem. If you have a
different problem (e.g., want higher sound quality) move on.
stereo system.
impossible.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
jessie25 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
On 4 Mar 2007 17:24:41 -0800, wrote:
It depends how those terminals are configured. If it's really
bi-wiring, both sets of outputs for each speaker carry exactly the
same signal. It's audiophile snake-oil. Just use one pair, ignore
the other.
But it's possible it's bi-amping. One amp for the treble unit in the
speaker, one for the bass. In this case, the speakers are specific to
the amplifier and you can't use the switching unit.
Perhaps if you told us the make and model of your amp and speakers?
the other.
Solution #3
Putty - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Be careful with this one! I have come across a Panasonic unit (sadly can't
remember the model number) that had an electronic crossover and twin power
amps per channel. The 'speaker boxes ( nasty plastic things) had no passive
crossover, just two drive units connected to the sockets at the back. This
unit certainly wasn't "upmarket", so I assume that Panasonic's accountants
worked out that these days, amplification and electronics are cheap, whilst
a passive crossover will cost more. If that's the case, then using 'speakers
with conventional crossovers won't work.
S.
S.
Solution #4
Brad - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
In <
at 05:24 PM, said:
It is possible that you cannot use a speaker selector with this unit,
but we need more information before we can be sure.
Please give the model number of the Panasonic unit.
How are the speaker terminals on the back of the Panasonic labeled? How
are the speaker wires labeled? Is there a mention of "Low", "Bass",
"Woofer", "High", "Treble", or "Tweeter", "A", or "B"? (this would be
in addition to "Left" and "Right")
Does your Panasonic owner's manual suggest how to connect extra
speakers to your unit? is there any mention of speakers in another
room?
spam:
wordgame:123(abc):<14 9 20 5 2 9 18 4 at 22 15 9 3 5 14 5 20 dot 3 15
13 [sorry about the puzzle, spammers are ruining my mailbox]
room?
spam:
Solution #5
pawa - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
ok
on the actual stereo box there are 8 terminals. each speaker has 4
wires coming from it. (there are 2 speakers)
i want to hook those speakers into a 4 way speaker selector. the
selector has 4 terminals per set of speakers. so i figured id wire
all 4 wires from speaker A into the 4 terminals in the selector and do
the same for speaker B, but on a new set of terminals on the selector.
but then how do i wire the 4 terminals on the speaker selector into
the 8 terminals on the stereo
Solution #6
Luisa_K - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
On 4 Mar 2007 15:56:08 -0800, wrote:
If this is bi-wiring in the usual sense - one pair of terminals
feeding two pairs of cables - it's snake oil. Ignore it, parallel the
input connectors. If it's something else, please explain fully.
Suggest a new solution for this problem
Post a New problem for Panasonic SC-AK500 CD Shelf System
Email this problem
Email this problem
Can you Help with these Audio Shelf Systems problems?
f61 problem,stereo turns on...
hey...can anyone help me with... Answer This...
Remote doesn't work
Remote doesn't work
When the remote stopped working... Answer This...
Player won't play 1st track
When a homemade CD is inserted,... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
