Question about Asko W640
Asko w640 has a water inlet fault
My asko w640 front loader starts the cycle and then stops after the wash cycle and advises water inlet fault.. When the washing machine first starts you can hear the machine start and then it takes about 5 secs before the water enters the machine. We have checked the inlet hose and all seems clear..?
  • SandyD Jun 09, 2013
    I am having the exact same problem with my W6222. I think it is an electronic problem which means getting the man in...$$$$$$
  • Asko Master
  • 3,361 Answers
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
  • billy musgrave Feb 15, 2016
    I hadbsame error and situation forbmy w6661 front loader.
    My work around as I don't use prewash was to change around the power cable between that inlet and the one that goes tibmy rinse cycle. Seems to have done the trick so most likely something was wrong with that piece.
    This requires that you turn off machine and unplug, take off top, and switch around 2 wires. Very easy to do and hopefully it works for you too.
Water Inlet Fault
check whether something is blocking the cycle.
Sep 19, 2008 | Asko W6461SS Front Load Washer
Asko Quattro 6661 water inlet fault
I had the same problem with my unit. The manual tells you to disconnect the water intake at the machine and clean the screen. This wasn't my problem because as you said the problem doesn't occur until the Rinse cycle which means there is water supply to start the Wash cycle.
From the back of the unit, remove the three screws and take of the lid. You'll notice that there are three separate motors do pump water inside the machine at the water intake. When standing in front of the machine, the motor on the right controls the rinse cycle. I connected an AC volt meter to that pump and started the rinse cycle. 240v showed up at the pump, but the water flow was poor. I simply squished up and down the rubber hose connecting this motor to the detergent unit and was unable to free the clog and water began to flow.
Jan 07, 2009 | Asko W6661 Front Load Washer
Machine wont stop filling with water, it just overflows. Machine is an Asko w6551 front loader
Same thing happened to my ASKO W600.  Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine.  Check it out and replace if necessary.
Oct 30, 2008 | Asko Washing Machines
Asko W640 water outlet fault
If you get the water fault after checking the lower drain, you may need to remove the drain hose in the back. Usually there is a dime in the hose or the hard part right before the hose.
Sep 11, 2008 | Asko W640
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Fault indication: water inlet fault
see if there is a blockage in the level switch. the switch operates on air pressure within the dip tube and the diaphragm in the switch. there may be a spider's nest in the tube or a wasp's nest in the tube.
Feb 03, 2008 | Asko W640
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Asko W600 spin cycle not working
Check the brushes oin the motor. It's the most normal fault when this problem appears. Not a big thing to fix for a technician!
Sep 24, 2007 | Asko W640
Washing Machines Logo
702 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
