Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Printer flashes alarm, clicks shows #345 how to remedy?
Canon MP390 won't work
Alarm flashes
disconcerting clicking
#345 shown intermittently
HELP
    President:
  • 2,692 Answers
HI I VE JUST BOUGHT A NEW PRINTERHEAD FOR MY CANON MP390 AND I GET THE ERROR WRONG CARTRIDGE ON THE DISPLAY. PLEASE HELP
You could try to reseat the printhead again.
Remove printhead, lower printhead lever, close cover.
Let printer to cycle to alarm condition.
Reinstall printhead.
Jan 11, 2011 | Canon SmartBase MP390 All-In-One InkJet...
Canon mp390 flashing alarm saying "put in cartridge"
The cartridge in this case is the printhead, not the inks. It's telling you the printhead is bad.
QY6-0054-000 around $60.00
Nov 13, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
I have a Canon Mp390 Printer/Fax/Copier which was working well. A neighbor called down and i sent a fax on her behalf. After which i copied some docum,ents to forward to my chemist whereby the printer...
I don't have that particular model. Is there a Canon dealer in your area who you can call to find out what the code means? Otherwise you might want to contact Canon through their own website.
I can tell you one thing about the Canon MP450 though. If any of the cartridges are empty the alarm light will come on and it won't send the FAX.
Sep 25, 2009 | Computers & Internet
Receive message 345 and alarm which prevents operation.
Other Canon models "may" be repaired with these instructions also, for example MP370, MP390, etc. Try with your own risk.
Symptoms:
-Grinding noise (very loud)
-Flashes error code ##345
Error code ##345 = "BJ cartridge head cleaning error" -reasons for this are:
-Foreign material or dried ink in head cleaning unit (also known as "purge unit") , or waste ink pump jammed up. Make sure waste ink pump rotates freely, after cleaning. Clean the waste pump-hose too! Waste ink pump is located under head cleaning system.
Short solution:
1.Take apart and wash the ink clogged mechanical parts. Use hot water.
2. Reset waste ink counter
purge unit: HM1-0723-000
see more parts: http://www.e-parts.fr/pictures/uploaded/files/MP_360_370.pdf
I hope this is useful
Sep 25, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MP390 printer alarm says INSTALL CARTRIDGE
Hello, johnnyandfay
Is the cartridge installed?
Aug 13, 2009 | Canon Office Equipment & Supplies
Canon mp390 flashing alarm put in cartridge
Can you send me a copy of the set-up sheet for the Multipass 390 by e-mail? andy.al@sympatico.ca
Mar 14, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Smartbase MP390 Printer - error code #345
"waste tank full" alarm; you may need to reset the waste tank counter.
Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Dec 17, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Smartbase MP390 Printer - error ##345
canon smartbase mp390 error ##345 check printer can anyone help me
Nov 01, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Jammed at far right (error message ##345)
hi
I don't know if you have the same problem as me but my printer kept saying cartridge jammed so I opened it up and moved the cartride head gently to the left and got a flash light there is a little peice of metal on the base where the cartridges sit you have to make sure it is cliked back in and now mine works again.
I hoe this helps
Sep 20, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon multipass 390
alarm is flashing and flashing put in cartridge even though I've put in both black and color new cartridges and reset both still won't print
Mar 25, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
167 people viewed this question
old marine
old marine
