Question about HP LaserJet CM1017 MFP All-In-One Color Printer
HP color laserjet 1017
Hi
I have a HP color laserjet 1017 , the problem is the self test is dirty , the white is not really white. The colors is good. I make a copy and this is dirty too. I change the black cartridge and that not solve this problem. The mirrors is clear. This problem apear after 2 week after instalation. It look like the toner is not the original, but it is . What can I do ?
Thanks.
    Novelist:
  • 217 Answers
Always with this printer 'engine', try your 'suspect' cartridge in another 'known good' printer, and a 'known good' cartridge in your printer.
If the problem follows the cartridge thats were the problem is.
If the problem stays with the printer, again, thats where it is.
Posted on May 09, 2010
My laser color HP cp1515n is not copy anything that's black copy? what can l do
Hi there, my name is Lisa and I'd be happy to help you with your LaserJet CP1515n. The following document will help you to troubleshoot the issue you have described:
HP Color LaserJet CP1215 CP1217 CP1514n CP1515n and CP1518ni Printers One...
I took a second look and found this one too:
HP Color LaserJet CP1514n CP1515n and CP1518ni Printers Resolving Print...
I hope this helps.
I work on behalf of HP.
Jun 19, 2015 | HP LaserJet CP1515n Printer
Default setting cm 1017
Hi there
Please find below a link to the HP site and the page from which you download the manuals
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/manualsResults/?sp4ts.oid=1846080
These should have all the information you need.
Good luck
Aug 25, 2014 | HP Color Laserjet Cm1015/cm1017 Mfp...
How to set hp color laserjet cm 1017 mfp to print black and white
Open the Printers Properties, settings, select your print preference.
Jan 01, 2013 | HP Color LaserJet 2600n Printer
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
HP LaserJet CM1017 MFP All-In-One Color Printer Logo
154 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
