Question about Canon Office Equipment & Supplies
Have to replace catridge
Procedure forgot to replace ink catride
    Sergeant:
    Champion:
  • 259 Answers
Hi, with the printer on just lift the lid the cartridge carriage will park it self in the middle of the printer the just remove the cartridge and replace with new cartridge after undoing it and removing the plastic cap over the ink outlet
Posted on Mar 10, 2009
Reset canon mx397
simply replace the cazrtridge with an OEM ( original manufacturer supply) cartridge and dispose of the third party cartridge- I haven heard of one instance where cheap ink refills have worked continuosly without destroying the Printer
Jan 16, 2014 | Office Equipment & Supplies
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
Can't print with black ink (photo 926)
hi
this is john
just u need to refilled ur black catridge if it does not work after refilling so replace ur black catride according to ur printer needs
this is a perfect solution
regards
bye
Oct 25, 2009 | Dell Office Equipment & Supplies
Printer goes thru all the motions but wont print installed new ink cart and still no luck
Thank you for contacting fixya.
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer.
Good Luck :)
May 06, 2009 | Office Equipment & Supplies
Ink system failure. Trouble shooting did not help. cleaned the cartidges and also brand new one replaced. it jus will not get off the ink system failure even when we turn it off and back on!!
Good Luck :)
Printer problems
In this case what i would request u to do is.......
Know insert both the catridges inside the Printer..........
Good Luck.............
Apr 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Not printing very well
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer
Feb 15, 2009 | HP DeskJet 810c InkJet Printer
Problem with printing page
Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........
Unplug the Power Supply from the printer.......
Replug in the Power Supply......
Try to Print it will work fine..........
Jan 05, 2009 | Lexmark X2500 All-In-One Printer
Brother MFC 3240C
I had the same problem. It corrected itself when I turned the printer power off and then back on after it went through it's shut down procedure.
Aug 14, 2008 | Brother MFC-3240C All-In-One InkJet...
Canon PIXMA iP4000
one trying is here
make sure you remove the sticker in catride ,it placed in near head of the ink catridge,and it marks so that
Mar 02, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
43 people viewed this question
old marine
old marine
Corne Viljoen
