Question about Delta Machinery 10" Professional Radial Arm Saw
Size of hole in 10inch blade for dewalt power workshop radial arm saw
  • David Ford
    David Ford May 11, 2010
    what is the model number and brand and I will try and help
  • Anonymous Mar 27, 2014
    manual for DeWalt 7770
  • 1,996 Answers
Most 10" saw blades are bored to fit a 5/8" arbor.
Unless someone has changed the arbor on your saw, I'd say that's 99% sure to work.
Are you making your own blades, or accessorizing? In any event, start with 5/8" and see where that gets you.
If you find this helpful, please take the time to rate my post. Thanks!
Posted on Mar 25, 2009
Need a manual for old DeWalt radial arm saw. Serial:60022464. NO model # on the plate.
check this out
20 Most Recent Dewalt 10" Radial Arm Saw 2 Hp Questions ...
Recent Dewalt 10" Radial Arm Saw 2 Hp 403044-made In Usa - Miter Capacity: 45° R 9.25" questions, problems & answers. Free expert DIY ... Serial:60022464.
Dec 11, 2016 | Dewalt Saws
Dewalt radial arm saw GW1- Is it single phase or 3 phase
if the plug on the cord fits any other outlet in the house it will be single phase
if the cord is cut , then it will have only 3 wires if it is single phase
( active , neutral and ground )
if it has 4 or more wires it will be 3 phase
most saws running a 200 mm blade or around that size and used for home duty will be single phase
the phase notation will be on the plate attached to the motor of the saw
It will read voltage , amperage, watts or hp, phase and cycles
Jan 02, 2016 | Dewalt Saws
Where can I find an owners manual for a Dewalt Radial Arm Saw Mdl # 02661
I would recommend clicking below. When you see a picture of your saw, open the link and contact the person who posted the picture on the internet.
Oct 16, 2014 | Saws
What size blade for Dewalt 1201DW radial arm saw
250mm x 30mm bore x how many teeth you want
Apr 06, 2014 | Saws
Blade size? for dewalt dw125 RAS
Here is the handbook download in a zip file. Should be very helpful for you.
DW 125 radial arm saw
Here is another download that may help too.
DeWalt Powershop Handbook.
May 15, 2012 | Saws
Normally DeWalt owners manuals are available from DeWalt ServiceNet (Click here),
But I have been unable to get any hits on that model number when I search the site. and I'm thinking you have probably purchased one of the older cast iron models, a 12 or 14", am I right?
Sometimes I've had luck finding manual for older machines at this link, but in your case I wasn't able to turn anything useful up there either...
In general, those saws had a two piece table, with a strip of 3/4" ply or particle board about 3-4" or so wide in back, and a wider piece in front, both about 3-4' wide. Between the two, on edge, sat a fence, approx.2 1/2" tall. The back table was sized so that the fence would be located in the correct reference to the blade, i.e. in front of the blade when the saw was pushed all the way back against its stop.. Then the thumbscrew clamps on either side of the table would squeeze the fence between the back section and the front section of the table.. The leveling screws beneath are used to level the table with respect to the path of the saw along the arm, so that, e.g., a tooth of the blade just skims along barely touching along its entire path of cut...
You can probably learn the correct sequence of adjustments for squaring the blade vertically and horizontally and adjusting for heel by examining other radial arm saw manuals, or perhaps consulting books on the subject...
Here's a link to an online forum on the subject
I haven't actually seen this book, but it looks interesting...Mr Sawdust
And finally, if you check back issues of Fine Woodworking online or at your local library, there are bound to be some articles on radial arms saws to help you along...
Sorry I couldn't hook you up with a manual, but I hope this helps... Good luck!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 10, 2009 | Saws
The size of the hole directlly relates to the size of the blade that fits on the saw, do not change blade sizes it is dangerous and will not fit properly
Mar 10, 2009 | Dewalt Factory-Reconditioned DeWalt DW432R...
Cannot find specs for my DeWalt Radial Arm saw
Here you go.hope this is what you wanted and Please rate this a fixya
Feb 09, 2009 | Dewalt DW746X 10" woodworker's table saw...
Delta Machinery 10" Professional Radial Arm Saw Logo
265 people viewed this question
Top Delta Machinery Saws Experts
Tom Chichester
ray gallant
Are you a Delta Machinery Saw Expert? Answer questions, earn points and help others
