Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Master Output Malfunction PLEASE HELP
Hi. I have a Pioneer DJM-600 Silver DJ Mixer (bought it new, and have had it for 3 years) and I have been able to keep the "Trim" level up at half way or more without any problem. Recently though, when I turned it on, the master output is completely distorted, far too loud, and forces me to have to turn my Hi, Mid, and Lo levels down to 1, -3, and -24, respectively (as listed in order above). Not only that, but I cannot do Master effects, I have to do it on Channels, 3 and 4 independently, but not through "Master" (which should cause all channels to have the effect processed on them); in other words, when the effects knob is on master no effect comes through, only when it is on an independent channel. Even through Headphones, the "Mixing" knob doess not distinguish "cue" from "master", or in between the two. That's why I believe I am having a problem with the master outlet, specifically. Does anyone have any idea(s) as to what the exact problem may be? I'm guessing it is a blown fuse, but what does a blown fuse even look like? Thanks for your help.
-DFT
Pioneer DJM 600 Master Out 2 Left Side Doesnt Work. any help please?
it could be a few problems,
1 - the left master connection to the board has come away (you would have to open up the mixer to detect this.)
2 - the master fader is faulty (you can tell this by checking your master level indicators are both on whilst music is playing, or tapping the fader.)
My advice would be to have it serviced or if under warranty speak to the store you bought it from. But if you feel confident and know what your doing u can find replacement parts on ebay etc.
Hope this helps a little
Jul 17, 2012 | Pioneer DJM-600 Silver Professional DJ...
DJM 500 Mixer not turning on
Seems that the power supply is down.
If your not a technician, visit one or bring it to your local dealer.
regards,
Gerard
Mar 14, 2010 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM 600 mixer keeps blowing ic 557 fuse on power supply board
I repair DJM 600 for many years. :) The reason for the burning of IC 557 (+8V H 600mA ) is invalid amplifier for headphones!!!
Replace IC 310 and IC 312 (in big mainboard), and replace
IC 557with original fuse 600mA
!!!!!CHECK YOUR HEADPHONES!!!!!! This is the cause burning amps.!!!!!
DJ Iskren
Oct 03, 2009 | Pioneer DJM-600 Silver Professional DJ...
New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 600
There is a master gain volume control on the rear of the mixer, where you connect everything. Make sure it's not down.
If it's fine, then maybe them being outside caused an issue. How cold is cold? If your talking freezing, then maybe there is some issues with the solder on the pc boards. You'll have to take it to a service center at this point.
I would say, try connecting a CD player to all the channels, and try from there. If it's still the same, then you need professional help.
- OPTiC
A DJ Pro Audio Co.
Oct 02, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM-600 black Professional DJ power on but not working!! i check bouth the fuses and are working i can see that is power in te mixer but no answer with any signal of leds or music signal
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
A DJ Pro Audio Co.
Sep 23, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 800. (dj mixer) when turning the master gain volume it doesnt turn the volume up or down unless you put pressure onto it.
apply some spray (lubricant contact cleaner)from radio shack-----to master gain volume and move it up and down many times.
Sep 09, 2008 | Pioneer DJM-600 Silver Professional DJ...
PIONEER DJM 600 MIXER KEEPS PEEKING RED SHOWING HI SIGNAL AT LOW VOLUMES
check your input (cables and device)for bad or short circuit cable-bad plug--connection between inner conductor and shield. of the cable(test with new one)------you can disconnect inputs one by one until you find the bad one.and change it.
Aug 27, 2008 | Pioneer DJM-600 Silver Professional DJ...
Help with set up
connect your gemini phono out to -------- pioneer phono in.
Jul 12, 2008 | Pioneer DJM-600 Silver Professional DJ...
292 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
