Question about Sony BRAVIA® DAV-HDX279W Theater System with Wireless Speakers
I have a sony hdx279w surround system, the center speaker is not working? I can not figure this out. I also...
You have to go to system menu and press up and down until "DEC.MODE" appears then press the right arrow press up n down again put it on "PRO LOGIC" that should work it did for me .good luck!
Posted on Mar 13, 2009
I've had my Sony Carousel CD player wiorking with DAV-HDX279W home theater system before. I used the TV/Video mode and it played. Now it doesn't. I can't find any setting that might have changed. ...
make sure the input is set to( analog in) on the stereo --this will enable the red and white jacks----it might have changed to digital which would enable the optical and coax jack--
Sep 05, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
I tried to plug Sony DAV-HDX279W into my tv with simply plugging yellow white and red into each unit but I get no sound.
common fault make sure the red and white are in the correct plugs as most units have 5.1 suround there are 3 sets of sound outputs use LF & RF
BEST OF LUCK
Aug 03, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
On my SONY DAV-HDX279W, the module that runs the rear speakers turns itself off after just a minute or two. In other words, my surround sound system won't deliver surround sound. Is this a short? Any...
are you using the speakers that come with it? its not typically recomended to use speakers not included with your htib system due to the diffrence in nominal ohms. however if you are using the original speakers check to see that the positive and negative wires are not touching. also check to see that there are no loose or cut wires if you have taken all of these precautions then most likely your unit is over heating due to prolonged use
May 24, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
My L/R surround speakers and my center speaker are not working. My Front speakers and my Subwoofer are working. When I plug in my L/R surround & Center speakers into, say, my front speaker ports the...
in most cases it is becaues there isnt a 5.1 channels be broad casted you have to use either an digital in or hdmi cable just ask some one at the store
May 12, 2010 | Sony DAV-DX255 System
Sony hdx279w surround
Your system should come with all the cables and connectors you need for the system. The rear speakers should plug directly into the back of the system using the speaker connectors that came with your system. If you are trying to add additional speakers then you need special connectors for that type of application. You can try www.BogueEngineering.com for special connectors. Hope that helps
Feb 12, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Cannot hear regular tv through speakers
you need to purchase either rca cables or optical cable
Jan 18, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony BRAVIA® DAV-HDX279W Theater System with Wireless Speakers Logo
406 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
