Question about V, Inc. VIZIO RP56 Rear Projection Television
Replaced bulb for Vizio rp56 DLP got power no light
I got no acton the indicator lights say lamp malfunction blinks green 3 times and ornage twice I replaced the lamp, what's wrong?
  • genevadudley Mar 16, 2009
    I did check that I had installed the lamp correctly and I had , the door was also closed. I smelled a burned odor that appeared to be coming from the ballast circuit so I removed it and noticed a cooper something appeared to have burned out. I am going to replace it but I'm wondering what would cause this in the first place. Did the fan that sits on top stop working and cause it to overheat? I don't want to put good money after bad I'd like to fix everything once and for all.
  • 4,234 Answers
There are interlocks that will prevent the set from starting if the lamp is not installed correctly or if the access door is not closed properly. Either condition will result in a "lamp error" indication. Try reinstalling the lamp being careful to be suer that it is seated properly. Also make sure that the access door is fully closed and aligned. If you continue to get the lamp error, it is possible that the ballast circuit is defective. This is the part that generates the power to "fire" the lamp.
Keep us posted.
Dan
Posted on Mar 10, 2009
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | Mitsubishi WD-62526 Projection TV
Televison & Video Logo
266 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
