Question about Whirlpool Duet GHW9150P Front Load Washer
Roaring noise during spin cycle
During spin makes a loud roaring noise. Sounds like it is coming from the back side of the tub. If you spin the tub by hand you can hear the noise as well but on a softer note. Have changed the water pump but it too still makes more noise than I believe it should. Repairman suggested changing the boot but admitted he really didn't know what was wrong. Hate to put more money into a machine when I could have practically bought a new one as it is. Machine is only three years old.
Help.
  • 188 Answers
The roaring noise is from the drum bearing and it will only get worse with time until it fails completely. You will need to replace the rear tub assembly which is about $300 for the part. The rear tub assembly part number is 285984. It will take about 2 hours in labor.
Make sure you are using HE (high efficiency) detergent and only about 2 tablespoons per load.
Posted on Mar 10, 2009
Washer drum making loud noise when spinning
Reach into the drum (on a front-loader)and push upward to see if it moves at all, you should feel no play where the drum support shaft passes through the bearings... The bearings will "roar" loudly during spin if the main seal has leaked water into them... Top-load washers will exhibit the same roaring if the seal fails in them also. Whirlpool Tub Seal and Bearing Kit W10435302
May 13, 2016 | Washing Machines
Maytag quiet series 100 noise during washing
Roaring noise must also come during the spin cycle I suppose...it seems your bearing and or drive belt/gear is causing you this noise. To fix this, you would need to completely disassemble the washer and inspect the bearing and or drive box that activates the turning motion. It is a large job.
Dec 02, 2013 | Maytag Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
I have a kenmore elite total care flex king size capacity plus quiet pak2 oasis that makes loud noises like a airplane when its in the spin cycle Model #110.28032701 which parts should be change?
If the washer is roaring during spin, the bearings are bad and you will need to replace the outer tub assembly.
Here is the part to order.
The part comes with a 365 day, any part, any reason return.
Nov 03, 2012 | Kenmore Washing Machines
My Whirlpool Cabrio WTW6200SW1; spin cycle loud roar
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 07, 2010 | Washing Machines
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Maytag Neptune model # mah6500aww: makes banging noise and causes machine to move
A loud banging sound in the pipes is usually caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The banging happens as the water hits the valve that prevents it from going any further. If the kinetic energy is great enough, it can actually cause a pipe to burst or explode at the end. If a valve is closed near the beginning or in the middle of a system, the water keeps flowing after that point, and it can actually create a vacuum. This vacuum can cause a pipe to implode if the stress is too great. Roaring type noises may be coming from a spin bearing. This bearing probably had the grease washed from it because of a tub seal leak.
Squeaking sounds in a new washer are usually caused by the new parts getting broken in, and will usually go away after several washes.
The sounds of water gurgling, slurping, or sloshing during a spin cycle are usually caused by the drain pump pushing the water out of the washer tub.
Too much water pressure can cause a whistling or squealing sound. Adjust the hot and cold intake water valves to relieve this sound.
Metallic clinking sounds during spin or agitation may be the result of drive train components meshing during speed changes or after a pause.
Swishing or swooshing type of sounds may be caused by water and suds trapped between the tub and basket during a spin cycle, and will usually clear up as the water is drained from the washer
Jul 29, 2008 | Maytag MAH6500 Neptune Front Loading...
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
683 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
