Question about Microsoft Xbox 360 Console
When i turn on my xbox 360 it works for only 2 minutes then the fourth red light comes and it doesnt work after that.help. wali mohammad arshad karachi,pakistan
  • 15 Answers
Well if the warrenty on the system console is still valid you can call the xbox company tell them an most likely they will exchange it for another one
Posted on Mar 10, 2009
Red flashing light and having a code E73
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Sep 06, 2010 | Microsoft Xbox 360 Pro System Console
2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
My xbox 360 has 2 red lights and when i turn it on, it only lasts minutes until the red lights appear
its called the red ring of death and it means ur xbox is breaking my friend didnt no this and got the red 3 times and now his xbox wont work let it chill for a couple of days idk if this will work but hopefully it will
Mar 08, 2009 | Microsoft Xbox 360 Console
2 Red Rings What is happenin??
These are the red rings of death, as they are called by the gamers who get them, ur system now no longer works. Go to google.com and look for the xbox 360 towel trick, if that doesnt work call microsoft and get ur system fixed by the experts!
RATE MY SOLUTION PLEASE!!!!!!!!!!!!!!!!!!!!!!!
Nov 25, 2008 | Microsoft Xbox 360 Console
Xbox 360 elite 1 red light
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
Xbox 3 red lights problem help please
3 red lights normally means there is a general hardware failure.
Are the lights flashing?
Turn off the xbox and...
Try unplugging everything from your xbox, plug it back in and turn it on.
if that doesnt work, when your xbox is turned off, take the hard drive out and restart your xbox. If it works with the hard drive, try restarting it again after putting the hard drive back in.
Apr 10, 2008 | Microsoft Xbox 360 Console
The xbox 360 red light flash
Assistance by phone seven days a week.1-800-4MY-XBOX
Dec 23, 2007 | Microsoft Xbox 360 Console
3 red lights
Microsoft offer a 3year extended warranty to sufferers of the 3 red lights.
Contact them on 0800-587-1102
Nov 26, 2007 | Microsoft Xbox 360 Console
3red lights, wont turn on
well,this happened to me one time, so I unplugged the cosnole and waited 15 minutes.. make sure the remote has fresh batteries too.  If that doesnt work, call microsoft, i heard they increased the warranty on xbox 360. 1-(800) 4MY-XBOX (469-9269
Oct 26, 2007 | Microsoft Xbox 360 Console
Xbox 360 Freeze!!
It's a common fault with X boxes, the red lights indicate overheating, so make sure it is well ventillated and if neccasary you can purchase an add on cooler for the system.
Dec 30, 2006 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
44 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
