Question about Sony Playstation 3 (PS3) Console
No power is going to the PS3. - Sony Playstation 3 (PS3) Console
  • magicmarsh May 11, 2010
    are any lights on the ps3 or anything, if not simply check the fuse in the plug
  • 275 Answers
Same thing happened to my first PS3 about a week after i got it, called SONY tech support to troubleshoot but did not work, they decided to send me a warranty replacement, I havent had an issue with my new PS3, I recommend you do the same
Posted on Mar 10, 2009
Dropped PS3 and it won't power on
If you dropped it and it won't power up now check the power button ribbon cables. If they are seated properly then you damaged the motherboard and you will need to replace the ps3. Don't drop them as they are fragile.
Mar 01, 2015 | Sony Playstation 3 (PS3) Console
Can the power supply on a PS3 be tested
Yes, best thing to do would be to go to a buyback games or check locally for information on testing a PS3 power supply.. Or you can google: How to test a PS3 power supply. good luck.
May 07, 2014 | Sony Official Playstaton 3 PS3 Power...
Sound but no visual
I think it's a setup problem..
Try this,
Turn your ps3 off.
Now turn your ps3 on by pressing and holding the power button until you hear the ps3 beep 3 times then let go of the power button.
This should soft reset your ps3 allowing you to re-setup your display options.
Aug 19, 2012 | Sony Playstation 3 (PS3) Console
Try to sign in and error code 8071053D keeps appearing
  1. Turn the PS3 to standby power off.
  2. Turn off the power on the PS3 by using the power toggle switch on the back of the PS3 and unplug power cord.
  3. Restart your wireless router, if using one.
  4. Plug in the PS3 power cord and power on the PS3.
  5. Try creating a new connection on the PS3 by accessing the Network Settings menu option on the PlayStation 3.
go for a minimum of 5 minutes in between each step to properly clear it
i hope this helps you and please vote for me
Dec 05, 2010 | Sony Playstation 3 (PS3) Console
Ps3
Hook up your PS3 using reglar A/V cables.
Then go ahead and turn off the the PS3. Then hold down the power button on the front and as your doing that turn on the PS3 from the back and make sure your holding down the power button on the front for 5 seconds.
At this point it should reset the setting to factory default and you'll get video. At this point you can go change the output to HDMI and then reboot the PS3 and you''ll get video thru that again.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
Alright you need to put your ps3 in what is called "safe mode". First make sure there is no disc in the ps3, then turn off the ps3 in the back(main power switch), turn that switch back on, then hold the power button in front until you hear a total of 3 beeps, then let go, the light will be red, hold the power button again and you will hear 2 beep then a quick double beep, let go of power button and the light should stay green. A menu will appear, try all option working your way up from option 1 until it works. If you go through all 6 option and you are still having issues call 1-800-345-7669 to have your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
Ps3 wont power all the way up
if you have moved your ps3 to a different tv or something, the video setting can get messed up, thus having to reset the video settings. here are a few steps to do so.
1. put your finger on the reset button and wait until the ps3 is in standby. (Keep holding your finger on it, don't let go)
2. turn off the ps3 completely by switching off the power switch (make sure your still holding your finger on the reset button)
3. turn your ps3 back on (while still holding the reset button) and you will hear a beep. keep holding the reset button until you hear a second beep. let go of the reset button as soon as you hear the second beep
this should reset the video of your ps3. ive done this to my ps3 before because when i was installing linux i almost screwed up my ps3. when i turned on my ps3 no picture or sound would appear. so i called sony and this is what they told me to do and it worked.
Jul 09, 2009 | Sony PS3 40GB Best Sellers Bundle Console
PS3 Problem... I turned on my ps3 but nothing shows up on the television screen and controls wont even detect... PS3 shows that it is receiving power because the power light on ps3 is green. Can someone...
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
Ps3 Not Working
Try a hard reset as follows
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format
Apr 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 no power
PS3 unit has fuses that probably failed. I wouldn't void the warrenty to try and change them yourself but this would be the place to start if you take it in for repair.
Jun 09, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
