Question about Epson Office Equipment & Supplies
Epson printer not working with windows vista
I have installed epson lq-2080 esc\p2 on my system with windows vista OS.Not able to print
  • 106 Answers
Pls check the manual of your printer if it is compatible in your O.S. Vista.. if yes, maybe some programs are conflict.. try to re set up yup O.S. then Install the printer driver.. ^^ don't forget to install your motherboard driver before installing the printer..
Cheers ^^
Posted on Mar 10, 2009
Windows 8 64 b
It seems the LQ 1170 was supported with the EPSON Universal P6 Printer Driver 1.1.0.10 2.0.0
.. up to Windows 7 but no further.
It seems the only likely solution is to just try plugging the printer in and crossing your fingers. If it installs the simple driver you're in luck.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=216556&foid=237145
Given the age of the printer and that driver specific support for the model was discontinued pre-Windows-XP it's unlikely other solutions will arise.
Jul 22, 2013 | Epson LQ Office Equipment & Supplies
Gerror 913 en lso archivos201 segenera por tener archivos desatualizado
Obten los controladores de Windows o MAc y actualiza tu printer.Si continua el problema escribeme.
Windows Operating Systems spacer.gif [+] Generic 9-Pin Printer Driver v1.0bEs
Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
epson10753.exe - 559KB - posted on 05/29/03
[-] Generic 9-Pin Printer Driver v1.0bEs
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
downloads_icon.gif Download Now
Windows 3.1
ep10759.exe - 527.2KB - posted on 05/29/03
Windows 3.1
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 3.1 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Windows 3.1 installation disks available as the printer driver requires the "unidrv.dll" file to complete the installation.
Macintosh Operating Systems spacer.gif [+] Network Printer Driver v2.0A
Mac System 7
EPRINT2N.SEA.hqx - 779.1KB - posted on 06/12/96
[-] Network Printer Driver v2.0A
Mac System 7
This self-extracting file contains the EPSON Print! 2 Network Printer Driver files for the 9-pin ESC P2, 24-pin ESC P2, and the DFX printers.
[+] Printer Driver (Serial) v2.0A
Mac System 7
EPRINT2S.SEA.hqx - 610.1KB - posted on 06/12/96
[-] Printer Driver (Serial) v2.0A
Mac System 7
This self-extracting file contains the Epson Print! 2 Printer Driver for serial connections with 9-pin ESC/P2, 24-pin ESC/P2, and the DFX printers.
Dec 17, 2010 | Epson FX 1170 Matrix Printer
PRINTING TWO EXTRA LINE ON @EJL 1284.4 @EJL ON EVERY FORM INVOICE AND CHECK EPSON LQ570+ RUNNING ON WINDOW 7
Windows 7 x64 & LQ-570+ ESC/P2 @EJL solution (should also work for other printers/OS, but not tested yet):
Try modifying .dpg file.
STEP 1:
Print the windows test page.
STEP 2:
There should be written the location and name of the file (Data file), so print the test page and look up the file path. It is located in the sam folder as dll (config file). In my case it is in "C:\Windows\system32\spool\DRIVERS\x64\3\".
(Sience I coulden't find x64 driver for LQ-570+ ESC/P2 I used LQ-590+ ESC/P2 Ver 2.0 driver. It's working ... )
STEP 3:
Now, when you found .GPD file, (make backup copy just in case) you have to add your computer account to list of accounts that has full controll of file or you won't be able to save changes.
STEP 4:
Delete only @EJLl 1284.4 and @EJL in line that looks like that:
*Cmd: "<0000001B01>@EJL 1284.4<0A>@EJL <0A1B>@<0D1B>t<011B>6<1B>R<001B>P<1B>(U<01000A>"
(If you delete anything else at that line it won't work ...)
STEP 5:
Save file an enjoy printig :P
If you have any question, write to riddle.xyz@gmail
Sep 01, 2010 | Epson LQ 580 Matrix Printer
I can't install on vista
i have a problem that i can't installing the wipro lq dsi 5235 dot matrix drivers in windows vista os
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
I want to increase speed of my epson lq300 esc p2
Change the print quality to draft mode that is the only way to speed this one up.
Mar 12, 2009 | Epson LQ 300+ Matrix Printer
Epson LQ-1170 ESC/P2 can't running in windows 98
You need a compatible driver to link the printer. Check online for driver compatability with older OS.
Feb 13, 2009 | Epson LQ1170 Matrix Printer
Epson lq 2080 printer problem
These steps apply to a Windows system.
1. Click on "Start", "Settings", "Printers".
2. Right click on the icon for your printer and left click on "Properties".
3. Click on the "Paper" tab. Here you should see a "Paper Source" option.
4. Make sure that "Tractor" is selected and not "Manual" as the paper source.
5. Once this change has been made click on "Apply" to save the change.
6. Now try printing a document.
Apr 26, 2008 | Epson LQ 2080 Matrix Printer
Drivers imprimante a aiguille epson
>go to printers & faxes
>click on add a printer
>select the port (LPT1)
>select the manufacturer (EPSON) then on the right-side of the window, scroll and search for your product
Jan 03, 2008 | Office Equipment & Supplies
EPSON LQ 1050+ printer; OS Windows XP, How to Print long pages of 24" length
My LQ1050 is cutting off text at the bottom what could be the problem please help?
Oct 12, 2007 | Epson LQ-1050 Matrix Printer
82 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
