Question about Zebra QL 320 Thermal Printer
Un able to configure zebra ql 320 plus barcoda printer
  • MJinfo May 11, 2010
    Do you have a serial or USB port on this printer? Do you have a matching cable?
  • 97 Answers
Are you using software called label vista from Zebra? this is the only way to configure this printers on a easy manner. you will need a usb or serial cable and also remember that if the printer does not have paper on it, it will not configure. let me know if you need more help with this as i know the product very well.
Posted on Jun 15, 2009
SOURCE: Zebra 170 III Plus
there is an option in the advanced menu to restore to factory defaults, you will need to get the password for the level 4 menu from the manual
Posted on Nov 09, 2007
SOURCE: ZEBRA QL 320 PLUS
Batteries have a finite life and its not very long probably 2-3 years.
What you describe is typical of laptop computer / printer batteries.
It would appear your battery is pretty much had it.
Your answer [probably] is to buy a new one or get the one you have repacked at a battery place that does repacking.
Unfortunately battery failure is the reason many people sell battery operated portable equipment. I would never expect a battery to be any good on second hand laptops or portable printers. People have never let me down in this expectation.
Posted on Jan 17, 2009
SOURCE: Hi There I've a zebra QL220 plus printer, the
How do you reset this printer to manufacture setting.. I keep getting a error communication with printer. My email address is christopher.wilder@stalexius.net
Posted on May 29, 2009
  • 31 Answers
SOURCE: need the output feed roller gear for the zebra ql
Zebra doesn't sell parts for the mobile printers. You will need to send it to Zebra repair.
Posted on Jul 01, 2009
ozztech
  • 285 Answers
SOURCE: Zebra QL 220 Printer Reset
download segull driver (wwwseagullscientific.com) install, go to the setings, there is the Reset to Factory Defult.
Posted on Nov 13, 2010
How ot change the font size, printed on QL320 plus Zebra printer
Contact Zebra Technical Support Phone: +1 877 275 9327
Fax: +1 847 913 2578
Kiosk Only: +1 866 322 5202
**Best Option will be to call them since it is a mobile printer**
Mar 10, 2011 | Zebra QL 320 Thermal Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Nov 03, 2010 | Zebra QL 320 Thermal Printer
Trying to configure network settings on a QL 420...will not take certain info like the gateway
Check to ensure the printer has a network card installed. if not it looks like everything is working correctly in label vista but nothing "takes"
Jun 16, 2010 | Zebra QL 420 Plus Thermal Label Printer
Zebra QL320 plus no bluetooth discovery
Turn the printer up side down and remove the battery. Undo the philips screw and remove the module from the top. re-seat it back on the main PCB and replace the screw and battery. if the module still doesn't work then it is more than likely it has failed.
Feb 12, 2010 | Zebra QL 320 Plus Thermal Printer
Zebra QL 420+ wireless printer works only without cipher/TKIP
Hi
With Label Vista
  • Go to Printer Tab
  • Define the com Port settings (use serial or usb)
  • Go to Printer settings
in network tab :
  • Put your network configuration ( IP address or DHCP,submask, gateway; ESSID, port number .....)
In 802.1X WPA
  • Select WPA WPA2
  • Authentification PSK
  • Put the username and password in EAP section
Mar 16, 2009 | Zebra QL 420 Plus Thermal Label Printer
ZEBRA QL 320 PLUS
Nov 07, 2007 | Zebra QL 320 Plus Thermal Printer
Zebra QL 320 Thermal Printer Logo
472 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
