Question about Epson Stylus C46 InkJet Printer
C46 printer. red light is permanently on.
Also. i can't remove the ink cartridges.
  • 106 Answers
Your printer was reach its maximum print warranty... it has a resetter.. try this link...http://www.ssclg.com/epsone.shtml
Posted on Mar 10, 2009
Replaced innk cartridges but computer says ink is
hi
clean the pins or the flat cable is in the side of cartridg and anotherone in the place that cartridg install in it
good luck
Jul 02, 2010 | Epson Stylus C46 InkJet Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Epson C46 - I want to change the black cartridge as I think its faulty but how do I change it when its still full of ink and red light isn't flashing ?
you can always change without worrying about the ink levels. Be careful though, make sure that the printer is READY for cartridge removal.. good luck!
Jun 20, 2009 | Epson Stylus C46 InkJet Printer
Red light flashing green light always on
One of your ink cartridge is running low on ink and you have to change it soon.If you installed the status monitor on the computer it shows which one has to be changed.
Jun 19, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Jun 15, 2009 | Epson Stylus C46 InkJet Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
I put a new black ink into my printer it seemed alright, then when I went to print a document it made a strange noise and the green light went out and the red light went back on. I have tried pressing the...
the cover over the cartridge was not closed properly is my guess - was the noise like a grinding sound? - if so, it was the toothed drive belt jumping teeth on the drive roller.
Turn off power to the printer and GENTLY pull the cartridge carriage back t the center using the drive belt. Next remove and re-insert the cartridges and make sure the cartridge cover is down and locked.
Nov 18, 2008 | Epson Stylus C46 InkJet Printer
INK REFILL
get a new printer...this one is truly unhappy
Jul 29, 2008 | Epson Stylus C46 InkJet Printer
Epson stylus c46 printer
u put the cartridge and press red button
Jul 15, 2008 | Epson Stylus C46 InkJet Printer
Flashing lights
Dear , friend
Please replace cartridge
Jul 08, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
85 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
