My durabrand sts98rw displays invalid region
Even the disc i play has the correct region, it says invalid region. it started when i accidentalt turned on the factory setting in the setup screen.
  • 59 Answers
If you go into your factory settings setup screen check there for what region its set to and if it is possible to change it, change to the correct one.
Posted on Mar 10, 2009
Invalid region When I put a disc in, I get this
This means that the region code on the disk (which determines where it may be played) does not match up with the region of your DVD drive.
Normally the region code can be changed, but only a limited number of times.
Try to make that if you buy a DVD online, it has the correct region code for your player
This may help https://images-eu.ssl-images-amazon.com/images/G/02/help/dvd-regions-mapv2-465x286.gif
Oct 22, 2013 | Televison & Video
Durabrand STS98RW
I need a manual for a STS98RW dvd home theater system
Jun 20, 2010 | Durabrand STS98RW Theater System
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
Can i make it region free?
HELLO
Turn on your DVD Player
Press OPEN on remote
Press 1 3 7 9 and the number of the region you want to use between 0 and 6. Use 0 for region free. You may need to press these buttons slowly. You will see XXXX on the TV. When you press the last number, it will display at the top left of the screen.
Now insert a disc (other than your own region) into the player and close it. It should load and play. Other region discs should play as well. If you didn't do it correctly it will display "Wrong Region".
When you turn off the DVD player it will keep the settings.
HOPE THIS HELPS ENJOY (:-)
Oct 11, 2009 | Daewoo DVG-9100N
WE have misplaced the remote control to the Durabrand STS98RW,theater system, how do we order a new one?
Hi
Thanks for using FixYa. You can place the order for remote control of Durabrand STS98RW on the following link---
Durabrand STS98RW Remote Control
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Durabrand Audio Players & Recorders
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Disc region incorrect
Power up, no disk in. Status says READ then INSERT DISC.
Press MENU (status reads invalid key icon)
Press 1 (status reads invalid key icon)
Press 9 Menu is displayed.
Press ENTER on the region, digit turns to "-"
Press 0
Press ENTER again
Press EJECT to clear the special menu.
PS If you're gagging to get at this and the remote doesn't work, pull out the tab that isolates the supplied button cell in the remote control :-)
Region 1 NTSC
Region 2 PAL
Region 3 NTSC
good luck
please mark the post with a fixya!
Jan 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
