Question about Canon IXUS 960 IS Digital Camera
Why is my memory card locked? How to rectify and delete pictures
    Problem Solver:
  • 11 Answers
Hi Aruna_Devana,
When you say locked do you mean "write protected?" If you look on the left side of the card there may be a notch in the card and a slider. Move the slider forward to cover the notch and you should now be able to use the card. If the slider moves back to 'lock' when you insert it into your camera, put on a bit of sticky tape, just enough to hold it in place, being careful not to cover any contacts on the card. Hope this helps.
Mark.
Posted on Mar 10, 2009
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Memory card is locked and cannot delete pictures
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 12, 2014 | Kodak EASYSHARE V1253 Digital Camera
Lock Memory card
Think the memory card has a write protection switch. Eject memory card and flip switch.
Jun 07, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
How to delete pictures in built-in memory, dmc-LZ7
connect your camera to a compter
click start click on computer you should see your camera click to open you should see your pictures on the sd card select the ones you want to delece right click delete
hope it helps
Apr 03, 2012 | Kingston 1GB Secure Digital Memory Card
Tried to delete some pictures but P850 Easy Share camera says it is locked. I did not lock anything but cannot seem to delete pictures on 2 gig SD to make room for more pictures. Some pictures were...
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 20, 2011 | Kodak EasyShare P850 Digital Camera
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Apr 26, 2009 | Pentax *ist D Digital Camera
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Memory Card Locked.... how do I un-lock it?
there should be a little swith on the side of the card. switch to the opposite and then try
Dec 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Your memory card has a small white "switch" on the side. Move the switch and your card will unlock. It is a saftey so you don't erase anything accidentaly.
Jun 27, 2008 | Canon PowerShot A560 Digital Camera
Canon IXUS 960 IS Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
