Question about Microsoft Windows XP Professional
XP Startup Problem
Hello, over the past month I've had difficulty with my copy of Windows XP Pro Corp. The problem occurs at startup after I input my password. Here are the problems:
- Task bar, desktop icons, start button, quick launch etc. do not appear and I am left with the mouse cursor and my desktop background.
- Should I be able to log in with desktop icons, start button etc., I have no sound capability and no network accessibility. It should be noted that I install my audio and network drivers from the same nVidia drivers CD which came with my computer.
- I can use Windows Repair from my XP setup installation, however when I do it is good for only 2-3 restarts before the problems reemerge.
- After a repair/reinstallation, my computer will lose its internet connection and prompt for a restart.
- I have ran scans of registry cleaners, anti-virus checks, adware scans etc. and that doesn't seem to fix anything.
- I have replaced my old nVidia graphics card with a newer ASUS graphics card while this problem was starting. I don't what effect, if any, it could have with these problems.
At this point I am clueless as to the true nature of this problem. Any help is greatly appreciated. Thank you in advance.
  • RomCorp Mar 10, 2009
    I did do a reformat of my C:/ drive after copying important data over temporarily to an external drive but the problem had reappeared after copying my data back. I've been doing repairs to get some temporary performance back before the problems reoccur. It could be a matter of reinstalling certain programs I use (Adobe Reader, VLC player, Firefox, video games etc.) but I've used these programs before for years.
    Problem Solver:
You wrote that you just repaired the windows. I think that it's not enough and that solution is usually inefficient. A more "healty" solution: format the partition "C" and install windows again and after, the drivers. That is to eliminate the possibility that to be a software problem. Be carreful what programs you install after, because the problem can appear because of a software you installed. So install the programs systematically.
Post back if the problem persists or is it solved.
Posted on Mar 10, 2009
  • luckydidi21 Mar 10, 2009
    Well, do the format again and install windows. Don't put back your backup, install just the necessary programs for you and  wait for a few days to see if the system is stable. If it is stable install the other programs systematically (one by one and wait after each install for some time to see if the system becomes again instable). Seems to me that you have a software problem and the problem is generated by one of your programs. Do what I told you and post back. Good luck!
How do i fix an error while attempting to read configuration data file \boot\BCD status 0c000000f
You will need to run "startup repair" if you can borrow a copy of a XP DVD (any copy will do ) then you can also run the repair you will need to boot from the CDRom drive with the disk in, may have to set BIOS to boot from CDRom first, go past the language screen then select the "repair option" use startup repair. If you cannot get a download of the repair or a copy of XP then boot your computer and press F11 then select "advanced" hit the alt + D key at the same time this will give you a command prompt. Type the following two commands at the prompt pressing enter after each one. Reboot to take effect:-
bootrec.exe /fixboot
bootrec.exe /fixmbr
Aug 12, 2014 | Microsoft Windows XP Home Edition
My windows xp startup disk with the os an drivers is no good microsoft says i need contack manufactures copy do have one
You should not have contact the manufacturer (microsoft)
one of these will help you
SP3 is the third and final service pack released for Microsoft Windows XP, and it eliminates many of the security holes that previously affected XP. While Microsoft recommends that users download SP3 using Windows Update, some users are unable to do so. However, it's easy to create a Windows XP SP3 installation CD; it requires only that you download the pack from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting the first link listed in the "Resources" section of this article. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en XP PRO SP3 ISO Download the iso also download the imageburn http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/ http://support.microsoft.com/kb/322389 http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid windows xp pro start up disc
post a reply if you need more help with this
Mar 12, 2013 | Compaq Presario sr1403wm AMD Sempron 3000+...
Hp Pavilion a6603w desktop pc will not boot up? locks up at microsoft corp page. Boot Disks lock up as well. even tryed old copy fo XP, still locks up before booting into windows.
During startup, or after you press the power button, Press F11 until the Recovery Manager opens. Follow the section to perform recovery.
Mar 03, 2011 | HP Pavilion a6603w PC Desktop
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
Sony VAIO model SZ330P notebook. How to create Startup CD
One easy way to make a startup CD: In your c:\ drive, find and copy the folder named "i386" to a blank CD. That folder is in c:\windows You might wish to use a CD-RW so that you can overwrite in case you make a mistake. You'll also need to find and copy these three files: regedit.exe, expand.exe, and winnt32.exe. These are also in the c:\windows folder. Keep in mind that if you have to use the disk someday, you'll need your XP product code, and you'll have to go into the BIOS and set the computer to boot from CD/DVD. Hope this helps.
Feb 27, 2009 | Sony VAIO VGN-SZ330P/B Notebook
Zone Alarm will not start up when I turn on my computer?
You can ADD the "Zone alarm" executable to your windows startup.
This can be done in 1 simple way.
1. Locate the "Zonealarm.exe" in your "Program files" folder. Usually your Program Files folder will be here "C:\Program Files". Just run a search for "Zonealarm.exe" inside this folder.
2. After locating the "Zonealarm.exe" file, right-click on that file. And select "Create Shortcut".
3. After that you'll find a "Zonealarm.exe" Shortcut file or icon inside the same folder.
4. Just COPY or CUT the shortcut file.
5. Now Right click on the "START" button.
6. Select "Open all users".
7. This will open a windows explorer window. Locate "Programs" folder and Enter it.
8. Inside you should locate "Startup" folder and enter it.
9. Once u ar inside the "Startup" folder, paste the already copied "Zonealarm.exe" shortcut file.
10. That's it. Now try re-starting the system.
Thanks
Dec 18, 2008 | Microsoft Windows XP Home Edition
Scanner
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution (if not got to Start> All Programs> HP> HP Solution Center) Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Sep 04, 2008 | HP OfficeJet 6310 All-in-One Printer...
Microsoft Windows XP Professional Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
