Will not read discs, Disc spins and laser *** moves,only way to get disc out is to switch off and hold open/ cosed button and switch on again.
  • 790 Answers
Hi
Maybe you have defective flex ribbon wire
Thanks!
Posted on Mar 10, 2009
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
PS2 Slim Disc Wont Spin
Sounds like the laser has gone out. The unit will not try to spin unless the laser can see the disc. A new laser can be picked up on ebay for less than $10
Nov 27, 2009 | Sony PlayStation 2 Slimline Console
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
Put in disc also same same
Google manual and model number to download a manual.
It sounds like the DVD player itself is not working, maybe you can see if the laser unit moves if you hold down the "closed/open" switch, DO NOT LOOK directly into the laser, it will damage your eyes, tilt the unit so you look in from "the side".
If it does not move try to touch the slider to see if it just needs a little help, remember it is fragile, it is positioned and moved by small plastic finns (do not know if it is the right word).
May 02, 2009 | Dual XDVD270 Car DVD Player
CDP 265 5-disc player
If the disc is actually loading but won't read, try cleaning the laser lens with a cotton swab. Unplug the unit and remove the cover to access the laser. Spray a small amount of glass cleaner on the swab and gently wipe the lens of the laser assembly. Use the other end to dry it and remove excess dust. The only way you can tell if the disc is loading is to remove the top cover and observe if the disc at least loads and spins. If it does, try that procedure.
If the disc doesn't come up to the loaded position and spin (spin the disc by hand to confirm this), your gears may be out of alignment. Take the disc out, and use a screwdriver to manually turn the gear from the bottom of the unit. The gear should be visible through a small hole in the bottom toward the front of the unit. Take a slotted screwdriver and turn it until you see the laser assembly come up to the clamp that holds the disc in place. You may have to force it slightly if the gear has skipped a notch, it might "pop" as it goes past the tooth. Make sure you are turning it in the same direction as it moves when loading a disc! Once you do that, the laser should come up completely and be able to clamp the disc and read it.
Dec 06, 2008 | Sony CDP-CE275 5-Disc CD Changer
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
I can not get my PSP to bring up games
open the door to the psp and turn it on. hold down a little black switch on the left side of the disc holder near the spindle. if the laser moves up and down and flashes red than the laser is fine. if the spindle spins ups a couple of times its fine. If both are functioning you need to take a qtip and move the laser all the way to the outside of the track b/c it is stuck and can't read the disc properly. let me know if you need more help. thanks
Aug 05, 2008 | Video Game Consoles & Games
Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
  1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
  2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
  3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
  4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Disc won't spin... laser doesn't come on...
ok...well all of you people are just **** him! the actual problem is that you probably dropped the ps2 and the case lid got a bit lose...... what you have to do (if you dont want to buy a whole ps2 case again) is tap the ps2 on the top of the lid when it goes into the cd browser screen and it will work perfectly fine just make sure you dont tap i too hard or else we will have another problem...lol!
Nov 17, 2007 | Sony PlayStation 2 Slimline Console
96 people viewed this question
 Grubhead
Grubhead
