Question about Microsoft PowerPoint for PC
Slides preparation for a paper presentation on eyegaze communication system
  • 407 Answers
Here are some templates to help you get started.
http://office.microsoft.com/en-us/templates/CT101423491033.aspx?av=ZPP000
Posted on May 22, 2009
Cannot find motor for sunroof in 1998 lincoln towncar limo
Before removing the motor ,check for B+ at the switch , in an out of the switch . Lincoln calls this a moon roof an there is a relay that powers it up . The location of relay an the motor is in the same place ,center of headliner behind the roof .
  • Sliding Roof Panel Does Not Open or Close
  • Damaged circuit breaker.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
  • GO to Pinpoint Test E .
PINPOINT TEST E: SLIDING ROOF PANEL DOES NOT OPEN OR CLOSE E1 CHECK WINDOW OPERATION
  • Operate window.
Does window operate? Yes No GO to E2 . SERVICE safety relay circuits. REFER to Section 01-11 . E2 CHECK SUPPLY TO SLIDING ROOF PANEL MOTOR
  • Remove roof sliding panel switch as described.
  • Turn ignition switch to the RUN position.
  • Using a voltmeter connected to a known good ground, check Circuit 400 (LB/BK) at roof sliding panel switch connector C900 for voltage.
Is B+ present? Yes No GO to E3 . SERVICE open Circuit 400 (LB/BK). E3 CHECK SLIDING ROOF PANEL SWITCH GROUND
  • Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at roof sliding panel switch connector C900 . Measure resistance.
Is resistance 5 ohms or less? Yes No INSTALL roof sliding panel switch. GO to E4 . SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system. E4 CHECK CIRCUIT 692 (R)
  • Using voltmeter connected to ground, back probe Circuit 692 (R) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the open position.
Is B+ present? Yes No GO to E5 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E5 CHECK ROOF SLIDING PANEL SWITCH
  • Using voltmeter connected to ground, back probe Circuit 691 (DB) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the closed position.
Is B+ present? Yes No GO to E6 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E6 CHECK SLIDING ROOF PANEL MOTOR
  • Gain access to sliding roof panel motor as described.
  • Using voltmeter, back probe sliding roof panel motor Circuit (DB) at connector C903 .
Is B+ present? Yes No GO to E7 . SERVICE Circuit (DB) for open. RESTORE vehicle. RETEST system. E7 CHECK CIRCUIT 692 (R/Y)
  • Using voltmeter, back probe sliding roof panel motor Circuit (R/Y) at connector C903 .
Is B+ present? Yes No REPLACE damaged sliding roof panel motor. RESTORE vehicle. RETEST system. SERVICE Circuit (R/Y) for open. RESTORE vehicle. RETEST system.
Sep 20, 2015 | Lincoln Cars & Trucks
Need help to write a presentation papers about 'child internet privacy'.Where could i get that?
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; line-height:115%; font-:11.0pt;"Calibri","sans-serif"; mso-bidi-"Times New Roman";}
Jan 24, 2014 | ParetoLogic Privacy Controls
How do I forward the slides of a powerpoint presentation using the remote?
Make sure that you connect a cable (usually the USB cable is supplied with the projector ) from the computer to the projector. Once communication is established, normal PPT slide advancing is done by pressing the up/down arrow keys (depending on the remote control layout)
Dec 18, 2013 | Epson Projector Remote Controller...
Preparation of PTU (MSCITLE) 3st semester exam
here you can get previous year's exam papers
https://brpaper.com/
May 23, 2017 | Answer Carbon Expert BMX Handlebar
Ano ang power point
PowerPoint is a presentation program developed by Microsoft. It is included in the standard Office suite along with Microsoft Word and Excel. The software allows users to create anything from basic slide shows to complex presentations.
PowerPoint is often used to create business presentations, but can also be used for educational or informal purposes. The presentations are comprised of slides, which may contain text, images, and other media, such as audio clips and movies. Sound effects and animated transitions can also be included to add extra appeal to the presentation. However, overusing sound effects and transitions will probably do more to annoy your audience than draw their attention. (Yes, we have all heard the car screeching noise enough times for one lifetime.)
Most PowerPoint presentations are created from a template, which includes a background color or image, a standard font, and a choice of several slide layouts. Changes to the template can be saved to a "master slide," which stores the main slide theme used in the presentation. When changes are made to the master slide, such as choosing a new background image, the changes are propagated to all the other slides. This keeps a uniform look among all the slides in the presentation.
When presenting a PowerPoint presentation, the presenter may choose to have the slides change at preset intervals or may decide to control the flow manually. This can be done using the mouse, keyboard, or a remote control. The flow of the presentation can be further customized by having slides load completely or one bullet at a time. For example, if the presenter has several bullet points on a page, he might have individual points appear when he clicks the mouse. This allows more interactivity with the audience and brings greater focus to each point.
PowerPoint presentations can be created and viewed using Microsoft PowerPoint. They can also be imported and exported with Apple Keynote, Apple's presentation program for the Macintosh platform. Since most people prefer not to watch presentations on a laptop, PowerPoint presentations are often displayed using a projector. Therefore, if you are preparing a PowerPoint presentation for a room full of people, just make sure you have the correct video adapter.
Jul 12, 2011 | Microsoft Computers & Internet
What are the uses of microscope
A compound lab microscope is generally intended for the following:
examination of prepared glass slides of: Organic Tissues organic fluids cells of plants and animals
The are used extensively in clinics to examine urine for the presence of gout or bacteria. Or to examine other body fluids.
Specimens need to be prepared on glass slides and sealed with a "glass cover slip". Prepared slides can be order from many different sources over the internet. Try searching "prepared specimen slides" or "prepared microscope slides" or use www.Microscope.com
A compound scope is not effective for examining things like insect structures, or any "solid" objects which light cannot pass through. For such research a "stereoscope" is required. The stereoscope directs light from above like a spot light.
Nov 07, 2010 | C And A Scientific My First Lab Microscope
Mp3 music on PPS when emailed does not work.
Yeah, because you linked it and don't have it set to export linked resources. If you ship the MP3 with the ppt and all directories are right, you're golden (or export with linked resources embedded and there you go.)
eMail readers are responsible for how the components are parted out; I can't see why it would stage all the components for playing in a particular way, it's kind of an insecure way to run.
Feb 13, 2010 | Microsoft Office PowerPoint Home and...
I can no longer access MS Office 2003 docs on my computer. It doesnt matter how I try to open them. The message states preparing to install, then a new msg pops up stating Installation source for this...
Hi! I don't know about your previous usage versions of MS Office on your system. I don't know about "genuine" concept over your present MS office 2003.
Mostly, for new system, office would available under trail version only, later it blocks.
Suppose if you tried to update present version to 2003, then there may be chances to loss of some files. At this point, you may get errors while accessing and at the same time, it may show you errors or starts for install process.
try to update your package with online update and with genuine key and have fine with office package
Dec 21, 2009 | Microsoft Office Outlook 2003 for PC
How do I scan slides?
If you're referring to a paper size slide for presentation, all you need is just place it under a white paper then scan as usual.
But if you're referring to a 35mm slide, you may want to refer to this step-by-step guide that I got from HP site on this link. Page 13 (page 18 on pdf).
Oct 22, 2009 | HP ScanJet 3970 Flatbed Scanner
Effective slides on paper presentation on wireless communication
Here are some templates to help you get started and give you some ideas.
Feb 01, 2009 | Microsoft PowerPoint for PC
Microsoft PowerPoint for PC Logo
162 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
