Question about Nokia 2600
About speedness & battery
Battery does not withstand 4 long time ........mobile s working too slowly.........speaker gets damage often......
  • 365 Answers
Try to put the battery from other same model phone and check
Posted on Mar 10, 2009
When applying the throttle my scooter surges. When I give it gas quickly it slowly declines when I give it gas slowly it gains speed slowly but never gets past 23mph
Hi Lynn, for hard starting the usual suspects are:
1. Enrichner system plugged, not properly functioning or improperly operated.
2. Fuel overflow.
3. Restricted fuel supply.
4. Plugged slow jet or passages.
5. Inlet system air leak.
For poor acceleration the usual suspects are:
1. Throttle cables misaligned or misrouted (may also affect idle speed).
2. Damaged or restricted fuel tank venting system.
3. Inlet system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
12. Enrichner valve not seated or leaking.
Good luck and have a nice day.
Jul 19, 2015 | GAS Motorcycles
Is a portable bluetooth speaker withstand water damage?
Does it still work OK? If so question answered. Similarly if not working.
Jul 07, 2015 | Skull Candy Pipe Speaker Dock for iPod and...
My question is will the speaker withstand the output of a power amplifier with a power output rating between 300-400 watts/ch RMS without damaging the speaker? T
First we need to know what speaker you are using. Second is that you need to know that you are not going to be using the amp for the full amount of output.
Jun 07, 2015 | Audio Players & Recorders
How do I test if the batteries are still working? I have not ride or switch on the scooter for at least 3 years.
Assuming you don't have a voltmeter and can't check to see if the batteries are producing 12.6 volts, remember that these batteries are around $36 each at Radio Shack and easy to replace if your hands are working. If it's really important, spend the $36.
If your hands don't, or you don't have a Radio Shack, a scooter replace shop locally charges $85 an hour, min one hour, to troubleshoot and diagnose the batteries, then will charge for the parts at around triple the Shack price. I'm sure there is a repair facility similar around your area.
To test the batteries without a voltmeter, charge the scooter overnight, get on in the morning, and starting at the slowest speed, go forward a little bit, slowly working your way up to the full speed. Stay around your charger, IOW don't go for a 3 mile ride, until you know if and how much of a charge the batteries are holding.
One last thought, in our scooter, new batteries only lasted 2 years and 2 weeks before losing their capacity. Our local "small town" Shack had the batteries in stock, so they seem to be a popular item.
Jan 29, 2013 | Pride New Mobility Victory XL 4 Wheel...
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN...
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Jul 05, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
My scooter sometimes seems to slow down for no reason on full power. It is like something it holding it back then all of a sudden it is working fine.
Hi. Could be a couple of faults. The throttle pot ( Wig Wag ) could be worn. While you are driving the machine, try moving the ends of the lever up or down slowly, ( not in and out as you usually do for driving ), and see if that makes the speed vary.
Another problem could be faulty battery or motor connectors. I have replaced or removed many battery connectors because of this. Also check battery or motor wirs where they connect to the controller.
If you feel unsure about checking the connectors, get a good serviceman to do it for you. Good luck. Neil.
May 12, 2010 | Pride Mobility Products GoGo Elite...
I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
May 12, 2010 | Electric Mobility 4 Wheel Heavy Duty...
The mobile nokia 6600 after it is opened it withstand for 4 hours then it shutdowen without any notice
i think there must be battery problem -it must not be in gud condition or it must be lose check ur battery then check your mobile
Feb 05, 2010 | Nokia 6600
It appears to be out of power but suddenly the power reappears I
ok, that could be one of three things,
A bad connection with the battery so lift the battery and check contacts,
Check wiring to the speed pot, you will have to remove the top unit that house the speed pot etc (Wign wam)
A faultly speed pot is the other cause, to confirm trying moving the pot up and down, is there a lot of play , try moving the lever slowly, if it jerks about, it needs replacing.
Regards
GeWiz.
Oct 17, 2009 | Shoprider Scootie 4 Wheel Scooter
Tomtom one 3rd edition, sound not working
My had the same problem after dropped on the stair. I did the reset but no help. Here what I did: uncrewed 4 torx crews and pop out the back cover slowly. remover speaker's wire connector and check speaker resistance 3-4 ohm. reattach connector firmly and did a speaker test in volume preferences menue. Mine works just fine after this attemp. In my case is a loose connection. The battery and speaker can be change as necessary.
Jun 28, 2009 | Tomtom ONE 3rd Edition GPS
Nokia 2600 Logo
26 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
