By Reynolds - usenet poster
Customer sent in dead unit, I managed to fix the lamp power supply, but the
unit is now lighting up a blue screen with no response to controls or input
signals. I think it's something else in the P/S, but I need to know the
output voltages so I can determine which one is dead. TIA...
A
Solution #1
posted on Aug 02, 2007
Bouncy - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I have a similar projector also with dead PSU however mine is an
Infocus LitePro 580 ( which is the same as the ELP-3000). The main
board is the same but the PSU is different. It is made by
Panasonic-MKE and uses a hybrid Mitsubishi device that is obsolete.
As I remember the ELP 3300 uses a Sony power supply but the main
projector board is the same. The supply rails are 5V, 12V and 18V.
There are two 12v inputs A and B. When run on a bench supply these
were tied together.
were tied together.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Epson Projector Lamp for PowerLite
Email this problem
Email this problem
Can you Help with these Multimedia Projector Replacement Lamps problems?
Continuity test for a projector...
Can I use an ohm meter to test... Answer This...
invert image on projector
i have a generic chinese... Answer This...
magnavox replacement remote...
a some where to purchase one in... Answer This...
image is flickering
image is flickering
The ?flickering? of the... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
