My Defy Automaid does not spin, runs through all the programs normally
Put the machine on its side and check the wires to the pump. i found one of the wires broke off the lug on the pump side. Could be from all the vibration from the drum. The machine will only spin if the drainage is working.
Good luck.
1) Check wiring on timer-there is a wiring diagram on the Internet.
2) Check for blockages on the water lines.
3) After running the machine under load for approx.20 minutes check the heat of the main motor.If this is hot,either get it rewound or purchase a new motor.
This is normally when the machine won't spin but still washes.
My model DAW285 does the same thing
I have the same problem at times
My Defy Automaid DAW 317 das not rotate or spin the drum but runs trough the program and take and pump out water normally. This problem is not permament.
