Model samsung hd204ui, It will not power up. I don't think it's fried as I opened it up and nothing seems burnt. I think perhaps the power unit in the casing is faulty?? Is there any way I can connect it to a western digital 3tb (WD my book essential) SATA, casing? Or to a desktop so I can try salvage some files?
SOURCE: Western Digital WD 1200VE; 120 GB external hard drive unable to boot
good eve prapad dont worry for your data ,first if you have a boot cd ,owerrite the OS ,then select repair option,it is occures due to 90% OS currupt ,
regards prasanna
SOURCE: Notebook does not recognize My Book / Western Digital hard drive
I have solved a similar problem to this. My laptop would not allow me to get to my WD Passport. The driver was fine and no errors were reported - it recognised the drive when I ran the hardware removal utility - I just couldn't see it from any of my windows applications and therefore couldn't get to any data.
The problem was that the passport was being designated as E:\ but my laptop already has a network drive mapped to E:\. When I am in the office the computer connects the network drive to E:/ and so my passport automatically picks the next available letter - F:\. Away from the office, the network drive is still buit shows as "disconnected network drive" and somehow the laptop gets confused into designating both the the passport and the disconnected network drive to the same letter. so the passport is not visible in My Computer.
To fix it I went to My Computer, right clicked on the disconnected network drive and select Disconnect from the options there. And hey presto the passport appeared!
You can see which letter your USB HDD is assigned in the device manager in XP. Right click on the device and go to the Volumes tab - click on Populate and the drive letter should be shown there. If that doesn't match what you see under that letter in My Computer it looks like you have a similar problem & so disconnecting whatever is there in My computer might help.
SOURCE: No power to my WD 1TB
If its under warranty then get it sent back.
If its not then almost any 3.5 " external sata enclosure will do so long as it has its own power supply. and if that supply is a wall-wart then should you pooch that, they are so easy to pick up and replace.
If you need quick access to the files remove the disk and fit it to a suitable computer.
If this information was useful please click
SOURCE: How to disable Autorun function
Have you tried renaming autorun.inf or the autorun folder to something else? This file or folder would be in the root directory of the drive.
That would be my guess.
Please be kind when you rate -- I admit this is a guess.
Thanks for using FixYa and Happy New Year
SOURCE: unable to format a Western Digital Caviar Green
In your formatting on a windows machine you can format by right clicking the new drive and select format. Or you can format by opening manager by right clicking on my computer and choose manage then go to disk management and locat the new drive and right click format
