Question about Samsung SCH-U470 Juke Cellular Phone
It all started When i clicked on the switch to NAM 2 mode. Then it said restarting and now all it says is initial programming needed. also when i click the ok button it says to enter the lock code but my regular lock code isnt workin and i already tried resetting it but it wont reset. My ph a samsung messanger
  • Anonymous Mar 20, 2009
    i have the same exact problem plz help
  • Anonymous Apr 01, 2009
    i have a samsung sway and this is driving me insane and i cant get anything from the damn website because everything has to be sent in a txt and i havent set my account completely up online
Http://www.fixya.com/support/t1532515-changed_samsung_juke
Oxzgen has the answer!
Posted on Apr 27, 2009
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 | Cell Phones
I had my metro pcs samsung phone set to lock on powerup. i was being curious and switched to nam 2 and it restarted but the lock code is not the same as the one i had set and it says initial programing...
type in #43574357* on your phone and it will give you some info ...you will see a ten digit number. The last four digits are the password for your phone
May 30, 2009 | Samsung Cell Phones
I had my phone in my pocket during a walkathon when I pulled it out it said initial programming needed. How do I perform the initial programming?
You accidentally switched to NAM 2. Simply go to the menu; tools and settings' phone settings; NAM selection; NAM. This should help.
May 03, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Initial Programming Code
you need to call samsung at 1-888-987-4357
and they will give you a code number generated from your esn# its free so dont worry
Jan 17, 2009 | Samsung SGH-R210S Cellular Phone
INITIAL PROGRAMMING NEEDED ON JUKE?
you can't fix it you have to get a new one...the same thing happened to me and im getting a new one
Dec 26, 2008 | Samsung SCH-U470 Juke Cellular Phone
My phone keeps on saying initial programing needed.
the solution is that you have deleted all files off your phone. so you have to take it to the verizon place so that they can reset it or if it's bad enough you can go get a new phone!!
Hope i was a help
Dec 24, 2008 | Samsung SCH-U470 Juke Cellular Phone
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
My daughter was messing around with the NAM settings switehed it fro NAM 1 to NAM 2 then the phone restarted and when it turned on it asked fro a lock code nothing she or I entered worked and it displays a...
The NAM is the internal cellphone number...every phone has 2 numbers...the one you use, and the one thats used to identify it... press *228 and then switch the NAM back to NAM 1
if that doesnt work take it back to your provider and they can reprogram it....however any contacts you had saved or music, pics, videos or downloads are gone for good...sorry
Apr 24, 2008 | Cell Phones
"initial programming needed" problem
I can not guarantee this Punksk8er but, i did the same thing with my phone by switching the battery with my mother's and I ended up with the initial programming needed sign. This is how i fixed it...
Go to...
>Menu
Select the option...
>Settings
Scroll down to...
>Phone Settings
Then Select the option...
>NAM selections
There you will see the options
>NAM1 &NAM2
Mine was on NAM2 and i switched it to NAM1.
The system restarted and the error "initial Programing needed" went away.
I am no phone expert or anything so I don't really understand how it works but i hope this helps you out dude.
Feb 01, 2008 | LG VX3300 Cellular Phone
Samsung SCH-U470 Juke Cellular Phone Logo
265 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
