The motor of my corsa bakkie 1600 cust out without warning. then when I try to start it, the engin just turns. it seems like it has no spark to the plugs. when I disconnect the battary and leave it for a while and reconnect it, then sometimes it does start. Sometimes it is when i want to start it after switching it off; other times it cuts out while I am driving. If I am driving fast enough at this point I put it in fourth gear and start it like that whilst the vehicle is moving. to me it seems like an electrical problem. where can i look for the problem and mabe fix it?
SOURCE: 2002 BMW 318ti - engine keeps cutting out while driving
right have a check down your local garage if they do diagnostics be about 15-30 pound well worth it tells you a hell of alot more then wht i can say here but on e46s any lil prob tht asc light wil come up its warning you cars not right beware in other words. ive had it on rear abs sensors the asc light is just warning but have them plug it in to diagnostics tht will tell you all about it and whts going on prob sensor somewere let me no how you get on..
SOURCE: Corsa Bakkie keeps cutting out when not applying gas.
Yo man, i have the same bakkie more or less same problem.Lights came on as i was driving on the highway and it just died...pre ecnition...Starts then dies again...bla bla bla.List goes on!
Start by replacing the Petrol pump relay!!!+- R400 i think.
Its next to your right foot ,next to gas pedal.Behind that cover.A small black box!
don't buy it from a dealer!
Good luck
SOURCE: Mazda Tribute 2002 engine cuts out randomly
I had a Mazda 626 with a similar problem, the car seemed to 'shut down' with no warning, even at highway speeds, as if I just turned the ignition key to 'Off'; After trying to fix it unsuccessfully by replacing several electrical parts, the problem was found to be a defective ignition switch, it was replaced and the problem went away.
SOURCE: Daihatsu applause intermittent engine problem
hey mate i have the same problem with my applause if u have found a reason for it i would love to hear it thx
SOURCE: Opel corsa bakkie-Cylinder 2 and 3 gives no spark
The ignition coil package is a kind of two coils. One is delivering to spark plug 1 and 4, the other is 2 and 3. So I think the coil is the problem.
