Question about Acer Aspire 5050-3242 Notebook
HP Pavilion Dv5-1008TU Hard Disk / Hard Drive not detected.
As i have tried reseating the hard drive, doing various tests (including the hard drive test, which only manages to come up with "Hard Drive Not Exist"), resetting the BIOS and system recovery none of these seem to work.
Any Help would be appreciated!
  • Acer Master
  • 32,281 Answers
The hard drive test could not detect the hard drive, indicates a faulty drive.
Also if the drive does not spin up or is making clicking sounds then the it is definitely faulty.
You need to buy a new drive.
Posted on Mar 10, 2009
HELP PLEASE WHEN I TURN MY LAP TOP ON I GET A FLASHING MESSSAGE THAT SAYSMEDIA TEST FAILURE CHECK CABLE
Media test failure Check Cable or error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
Mar 30, 2011 | HP Pavilion ZV5000 ZX5000 Compaq R3000t...
I am getting the error message-"Hard drive not
it caused the hard drive malfunction try open the bios and try to read the hard drive is your hard disk stll there. in some case on the hp compaq laptop the hard drive was detecting eror but it can be use to external hard drive.
you can find some usb to mini ata or usb to sata to try your hard drive on another laptop or pc(make it external hard drive)
Jan 14, 2011 | HP Pavilion dv5-1132us Notebook
I have an HP Pavilion dv6500, and while I was working on my laptop it suddenly shut down by itself and restarted. When it rebooted, a message came up saying "Operating System not found". I...
Your hard drive may have failed.
I suggest you remove your hard drive and re-connect it to your laptop to make sure it is make proper connection. Boot up and go into the BIOS to see if the hard disk is detected.
If the hard disk is not detected then most likely the hard disk has failed.
To get your laptop working, you will need to purchase a new hard disk and install Windows on the new hard disk plus the Pavilion device drivers and your programs,
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Dec 18, 2010 | HP Pavilion dv6000z Notebook
Pxe-e61 media test failure
This POST error refers to possible fault with the disk controller or the hard disk. Most likely you have a faulty hard disk.
Try reseating the hard drive first and if the problem remains then you need to test the hard drive. Do this by removing the hard drive and connect it to an USB hard drive adapter and connect the adapter to a working computer's USB port. If this computer see this as an external hard drive and you can open the various folders and files, then the hard drive is OK and the fault is the disk controller on the laptop's motherboard.
If the hard drive is not recogonized then it is faulty and you need to purchase a new hard drive, install Windows etc. to get the laptop functioning again.
Jul 09, 2009 | Toshiba Satellite 1805-S274 Notebook
My dell inspiron 1525 notebook comes up with error code 0141. Hard Drive - No drive detected
WHEN COMPUTR STARTS PRES THE F2 BUTTON , IT WILL TAKE U TO THE SYSTEM SETUP , GO TO ONBOARD DEVICES , OPEN AND GO TO FLASH CACHE MODULE AND DISABLE ( OFF ) THEN GO TO SATA OPERATION ALSO IN ONBOARD DEVICES , SET IT TO BE ON ATA NOT AHCI , THAN AND SAVE !!!! DONE ,NOW U CAN DO WHAT THATS IN UR MIND FUTHER QUESTION OR WANT TO EXCHANGE IDEAS EMAIL ME ON JAYSPRUNG@GMAIL.COM HALLA AT ME
Jun 10, 2009 | Dell Inspiron 1525 Notebook
Complaining about hard disk not inserted
The problem is either the BIOS is not detecting the hard drive or the hard drive is faulty or the disk controller is faulty. Check the BIOS setting to see if it has detected the hard disk, and if there is a hard drive diags run it to test the hard drive. Try reseating the hard drive and if it doesn't work, remove the hard drive and connect it to an USB hard drive adapter. Plug this adapter into a working computer's USB port and if this computer detects this as an external hard drive and you can view and open the various folders and files, then the hard drive is OK. If you haven't any files or folders in the hard drive, then format the hard drive from this computer to test this hard drive. If the hard drive is OK then the fault is probably the disk controller. If the hard drive is faulty, then you need a new hard drive in your computer.
Jun 10, 2009 | HP Compaq nx9420 Notebook
PXE-E61: media test failure check cable
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 18, 2009 | HP Pavilion dv1000 Notebook
Harddisk is not getting detected
You computer cannot find your hard disk. The hard drive could be faulty or the hard disk controller has failed.
Reseat the hard drive (remove it and install it again), this may fix your problem with the connector on the motherboard.
If reseating doesn't work, the hard drive may be faulty, remove the drive and insert it into a USB hard drive adapter and plug it into a working computer's USB port, if this computer see your hard disk as an external drive and you can see the contents of the hard drive then it is OK and the fault most likely is the controler in the laptop.
If you cannot see the hard drive then the hard drive is faulty. To get your laptop operational again, you need a new hard disk and need to install Windows on the new hard disk together with your
Apr 28, 2009 | HP Compaq Presario CQ60Z Notebook
How to install xp in hp dv 2918tx laptop
This is a Vista laptop with a SATA hard drive. Windows XP does not have the SATA drivers, you therefore must slipstream the drivers to a new installation disk
Mar 11, 2009 | HP Pavilion dv2000t Notebook
My hp pavilion 4200 i took the hard drive out and put it back in when i booted it up it says media cable not found then it says operating system not found. tried to run the operating system cd and it says...
The laptop can't find a hard disk, eirher the hard drive is faulty or not seated properly.
Take out the hard drive and reseat it again then see if the laptop boots up. If it still can't find the hard drive, listen to the hard drive, is it spinning up, is it making clicking noises? This indicates a faulty drive and needs to be replaced.
You can also test the hard drive by removing the hard drive and attaching it to a USB hard drive adapter and then plug it into a working computer's USB port. If the hard drive is OK then the computer will see it as an external drive and you can view and open the files.
Mar 08, 2009 | HP Pavilion ze4200 Notebook
Acer Aspire 5050-3242 Notebook Logo
983 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
