Question about Canon imageRUNNER 210S Copier
E051 - Canon imageRUNNER 210S Copier
    Sniper:
  • 54 Answers
EO51 IS A HORIZONTEL REGISTRATION MOTOR GEAR COMPLAINT .CHANGE THE GEAR OR MOTOR.
Posted on Mar 16, 2009
Error code e051
the horizontal registration home position detection mechanism has a fault
May 01, 2014 | Canon imageRUNNER 400 Printer
Canon ir 400
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again thre is a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Sep 15, 2013 | Office Equipment & Supplies
Toshiba estudio 167 E051
E051 use to be a false duplex jam on the IR-550 and was always a bad MSW5 switch causing the problem
Sep 20, 2012 | Toshiba Office Equipment & Supplies
I want see error code E051 the picture
E051 The home position of the side registration cannot be detected
within a specific time.
There is a delay in your registration unit, it is responsible for feeding the paper in time for no delay in the image. Regularly electromechanical clutches are controlled by you can see from the back of your machine.
Start by cleaning to after dressing.
Apr 30, 2012 | Canon Office Equipment & Supplies
My machine shows E051 error how to solve this problem.. Switchmain power off & on E051 is the total display of my machine can u please give me a solution for this
E 051 IS PROBLEME OF REGISTRATION MOTOR SENSOR NOT OPERATING.THIS MAY BE DUE TO NON MOVEMENT OF SLIDER FOR FAILURE OF GEAR BREAKAGE OR OBSTRUCTION FOR ITS MOVEMENT.LOCATION AFTER OPENING RIGHT DOOR JUST BELOW FEEDER METAL PLATE.
Jun 27, 2011 | Canon imageRUNNER 400S Copier
Just got this used canon imagerunner 330s. It seemed to be working OK but now wont finish powering up and displays an E051 code. Can I clear or bypass this? What does this code indicate? Thanks, Keith
Error code E051 indicates there is a problem with the movable paper guides in the duplex unit. Check that the rear connector for the Duplex unit is clear of paper or toner
Feb 16, 2011 | Office Equipment & Supplies
Canon Gp 335 E051
E051 indicates that the side or horizontal registration sensor is not detected try to switch off/on the machine but if the same error code display again thereis a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 17, 2009 | Canon imageRUNNER 400S Copier
My mich suddenly shows that E051 error can any one help me
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again there is a small motor that drive the sensor assy should be change.try to move the sensor manually by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 07, 2009 | Canon Office Equipment & Supplies
ERROR CODE E051
Jul 03, 2009 | Canon imageRUNNER 210S Copier
What is that eror code E000051-0000
E051-0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
because The horizontal home position sensor is faulty or the horizontal registration motor is faulty.
Dec 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 210S Copier Logo
93 people viewed this question
old marine
old marine
