Engine crank by it wont start
SOURCE: hard starting for my yamaha
see if you have gas in the oil. The carb float needle isn't shutting off full and letting gas seep into the cylinder and into the oil.
SOURCE: accelator cale playing up on yamaha majesty 250.
The correct term is Throttle Cable. use needle nose pliers to remove it from the grip, take your new cable and run it the same way the old one was ran. follow the old one, then take the old cable out after installing the new cable.
SOURCE: i need a clutch diagram
You can go to durantcycle.com and click on the online parts fiche then go to scooters and yamaha and then the year and the model will appear for that year. Then look up clutch and it will give you a expoded view of the clutch diagram. I hope this helps.
SOURCE: Yamaha majesty YP125 scooter. The needle of the
You have either a faulty sender unit in the fuel tank or a faulty guage.
