I have an Optimus LAB - 1100 automatic turntable i was wondering how you burn your LPs onto CD
  • horkscottage Apr 04, 2009
    Hello, I have a Optimus LAB-1100 and would love to save my records to cd, I was wondering if I need anything else to do this.
    Kind regards
    Bob
Stopped working - i took turntable apart - the wires controlling start, stop & cue are loose. i don't know where to reconnect them.
Posted on Jan 24, 2011
My Optimus LAB 1100 is playing 45s ok but the 33s sound like the chipmunks
the turntable speed is incorrect
adjust with the speed control setting
many quality turn tables have bar codes around the outside edge and when viewed under a light those bars appear to be stationary when the correct table speed is set
It is a strobe affect in time with the frequency of the light
Dec 06, 2015 | Audio Players & Recorders
HOW TO INSTALL A BELT ON A OPTIMUS LAB-1100 FULLY AUTOMATIC TURNTABLE
See:
http://www.youtube.com/watch?v=FTJd_WbEhEs
If you have difficulty lifting the platter off, raise it as far as you can and gently tap the spindle with a sift-faced hammer.
Sep 23, 2014 | Audio Players & Recorders
Connect optimus lab 1100 to macbook
The type of computer is not relevant. This turntable provides output at nominal "line level" and can be connected to your MacBook with a properly shielded audio cable through the audio input.
For best results, you might want to disable automatic-gain-control (AGC) in the "Sound" preferences pane in the "System Preferences" panel, and set the level manually such that the input does not overload.
As I mentioned above, the signal level is nominally "line level", and that can mean very different things depending on context. You might find that using a passive volume control (potentiometer) between the turntable and the computer's analog-to-digital converter can greatly improve the quality of sound.
Jun 20, 2014 | Apple MacBook Pro Laptop Computer with...
How do I replace needle on Optimus Lab 1100
The manual for the Optimus LAB-1100 can be found here: http://support.radioshack.com/support_audio/doc63/63393.pdf
Replacing the needle is on page 13. I did it and it was easy.
Cheers, Gordon.
Dec 18, 2012 | Audio Players & Recorders
Optimus lab 1100 turntable
what is the best recording software for the optimus lab 1100
Jan 31, 2009 | Computers & Internet
Replacing needle
Cheers, Gordon.
Nov 24, 2008 | Audio Players & Recorders
Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Aug 07, 2008 | Audio Players & Recorders
Record LPs into desktop computer.
If you have an line level audio output on the shelf unit, you can as then the other end would connect up to your input to the sound card, if there is only a mic. input and no line input you can get whats called an antenuator, or get another audio sound card for the computer with a line level input jack. Good Luck
Mar 21, 2007 | Teac DC-D6300 CD Shelf System
913 people viewed this question
 Grubhead
Grubhead
